Introduction
After deciding that the motor is functional and the power is indeed reaching the motor in the trigger housing, the motor housing will have to be removed and maybe replaced.
Pièces
Aucune pièce spécifiée.
On the front of the drill, remove the three 2" flathead screws connecting the front housing to the rear housing.
Use the socket wrench to remove the 0.5" length screw from the bottom of the handle.
Presque terminé !
To continue reassembly, simply follow the guide backwards starting at step 2.
