Aller au contenu principal
Skirt Lining Replacement
Ce dont vous avez besoin
  1. Skirt Lining Replacement, Lining: étape 1, image 1 de 2 Skirt Lining Replacement, Lining: étape 1, image 2 de 2
    • Cut out the old or damaged skirt lining. This can be done using a pair of scissors, or a razor blade/seam ripper if you have one.
    • Blades might give you a neater finish after this step but take longer to use.
    • Be careful when using sharp objects.
  2. Skirt Lining Replacement: étape 2, image 1 de 2 Skirt Lining Replacement: étape 2, image 2 de 2
    • After threading the needle, take some new lining (chiffon or silk material), iron it out, and make sure the lining isn't longer than the actual skirt.
  3. Skirt Lining Replacement: étape 3, image 1 de 3 Skirt Lining Replacement: étape 3, image 2 de 3 Skirt Lining Replacement: étape 3, image 3 de 3
    • Gently insert the threaded needle. Be careful not to prick your finger.
    • Push through the skirt fabric from below.
    • Pull the needle all the way out to form a stitch.
  4. Skirt Lining Replacement: étape 4, image 1 de 1
    • Continue with step 3 until you create stitches around the whole waistband of your skirt.
    • It should look somewhat like this when you make it halfway around the waistband of the skirt.
  5. Skirt Lining Replacement: étape 5, image 1 de 1
    • Cut out extra fabric if you have any, and here's what the waistline of your skirt should look like.
    • Try it on!
Ligne d'arrivée
Rena
Membre depuis le 01/11/24
121 Réputation
1 tutoriel rédigé
Équipe
York University, Team O-2, O'Regan Winter 2024 Membre de l'équipe York University, Team O-2, O'Regan Winter 2024
YORK-O'REGAN-W24SOG2
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 21
Total : 90
