Aller au contenu principal
SkullCandy Hesh Auxiliary Cable Replacement
Ce dont vous avez besoin
  1. SkullCandy Hesh Auxiliary Cable Replacement, Determine the damage: étape 1, image 1 de 1
    • Gently gripping the auxiliary cable of your headset, run your fingers down it's length, feeling for bumps or tears in the plastic sheathing. If there are multiple damaged areas, choose the one closest to the device.
  2. SkullCandy Hesh Auxiliary Cable Replacement: étape 2, image 1 de 1
    • Using wire cutters, cut the auxiliary cable at the determined damaged area.
    • Next, cut your replacement cable to the same length of the removed portion of the damaged cable.
  3. SkullCandy Hesh Auxiliary Cable Replacement: étape 3, image 1 de 2 SkullCandy Hesh Auxiliary Cable Replacement: étape 3, image 2 de 2
    • Using the spudger tool, grip and remove approximately an inch of the plastic sheath from the device's working wire and from the new auxiliary cable.
  4. SkullCandy Hesh Auxiliary Cable Replacement: étape 4, image 1 de 1
    • Use the spudger tool to remove the coating on the smaller colored wires inside the wire attached to the device and the new auxiliary cable.
    • Twist together the same colored wires from the device cable and the new cable.
  5. SkullCandy Hesh Auxiliary Cable Replacement: étape 5, image 1 de 1
    • Wrap each of the individual colored wires with electrical tape to insulate them from the other wires.
  6. SkullCandy Hesh Auxiliary Cable Replacement: étape 6, image 1 de 1
    • Secure all wires with a layer of electrical tape wrapped around the location of the splicing.
Test your device by plugging it into a compatible device using the auxiliary cable and playing a sound.
Sarah Burk
Membre depuis le 01/15/15
247 Réputation
3 tutoriels rédigés
Équipe
USF Sarasota-Manatee, Team 1-1, Stewart Winter 2015 Membre de l'équipe USF Sarasota-Manatee, Team 1-1, Stewart Winter 2015
USFSM-STEWART-W15S1G1
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 20
Total : 1,044
