Aller au contenu principal
SkullCandy Hesh Size Adjuster Replacement
Ce dont vous avez besoin
  1. SkullCandy Hesh Size Adjuster Replacement, Determine the damage: étape 1, image 1 de 2 SkullCandy Hesh Size Adjuster Replacement, Determine the damage: étape 1, image 2 de 2
    • Locate the break in the device.
  2. SkullCandy Hesh Size Adjuster Replacement: étape 2, image 1 de 1
    • Use a Phillips #0 screwdriver to remove the two 9 mm screws from the bottom inner casing beneath the break.
  3. SkullCandy Hesh Size Adjuster Replacement: étape 3, image 1 de 1
    • Remove the bottom inner casing to reveal the wire compartment and the port where the slider inserts.
  4. SkullCandy Hesh Size Adjuster Replacement: étape 4, image 1 de 2 SkullCandy Hesh Size Adjuster Replacement: étape 4, image 2 de 2
    • Cover the detached slider port in a generous layer of Plasti Dip, which works like glue. Also coat any exposed wire to seal the circuit.
  5. SkullCandy Hesh Size Adjuster Replacement: étape 5, image 1 de 1
    • Realign the broken size adjuster into the port with the Plasti Dip so that it can be secured to the ear piece.
  6. SkullCandy Hesh Size Adjuster Replacement: étape 6, image 1 de 1
    • Clamp the pieces in place by hand or with a binder clip until the Plasti Dip dries. Feel free to use a hair dryer on a low setting to speed up the process.
To reassemble your device, reattach the bottom inner casing with the Phillips #0 screwdriver and two removed screws.
Sarah Burk
Membre depuis le 01/15/15
247 Réputation
3 tutoriels rédigés
Équipe
USF Sarasota-Manatee, Team 1-1, Stewart Winter 2015 Membre de l'équipe USF Sarasota-Manatee, Team 1-1, Stewart Winter 2015
USFSM-STEWART-W15S1G1
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 11
Total : 743
