Aller au contenu principal
SkullCandy INK'D 2 Audio Jack Replacement
Ce dont vous avez besoin
  1. SkullCandy INK'D 2 Audio Jack Replacement, Audio Jack: étape 1, image 1 de 2 SkullCandy INK'D 2 Audio Jack Replacement, Audio Jack: étape 1, image 2 de 2
    • Use wire cutters to remove the audio jack.
    • Use wire cutters to remove approximately 1/2 inch of insulation of the wire and separate the four wires inside of it.
    • Red wire is the right speaker '+' terminal.
    • Green wire is the left speaker '+' terminal.
    • Golden wire is the ground terminal.
    • Purple wire is the microphone terminal.
  2. SkullCandy INK'D 2 Audio Jack Replacement: étape 2, image 1 de 1
    • Take the replacement connector and separate the wires on it.
    • Red wire is the right earphone.
    • Green wire is the left earphone.
    • Blue wire is the ground terminal.
    • Gold wire is the microphone.
  3. SkullCandy INK'D 2 Audio Jack Replacement: étape 3, image 1 de 1
    Outil utilisé dans cette étape :
    Heat Shrink Tubing Assortment
    $7.99
    J'achète
    • Put shrink tubing on either one of the wires.
    • For each wire color, put the headphone wire and the replacement wire into clamps. Weave them together using fingers.
    • Review the soldering guide before initiating Step 4.
  4. SkullCandy INK'D 2 Audio Jack Replacement: étape 4, image 1 de 1
    • Use soldering equipment to solder together two wires.
    • Repeat this step for each of the four wire colors.
    • Always wear safety glasses when soldering.
  5. SkullCandy INK'D 2 Audio Jack Replacement: étape 5, image 1 de 1
    Digital Multimeter
    $19.99
    J'achète
    • Using Digital Multimeter in the "Continuity" mode, place two probes on the soldered wires of the same color. You will hear audio signal indicating that there is a connection.
    • Repeat this for each of the wire colors.
    • If there is no Multimeter signal, you will need to resolder the wires and to make sure that wires of different colors are completely separated.
  6. SkullCandy INK'D 2 Audio Jack Replacement: étape 6, image 1 de 3 SkullCandy INK'D 2 Audio Jack Replacement: étape 6, image 2 de 3 SkullCandy INK'D 2 Audio Jack Replacement: étape 6, image 3 de 3
    Heat Gun
    $24.99
    J'achète
    • After all wires are soldered, cover them with shrink tubing.
    • Use the heat gun to shrink the tubing and fit it tightly around the wires.
    • Gently apply heat in order to shape the tubing around the soldered wires.
Repeat the procedure if you need to install a new audio jack.
Maksim Bondaruk
Membre depuis le 10/16/17
119 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S4-G1, Livingston Fall 2017 Membre de l'équipe Cal Poly, Team S4-G1, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G1
5 membres
25 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 25
30 derniers jours : 120
Total : 15,463
