Introduction
This is a guide to replace your Skullcandy Air Raid's Speakers.
Ce dont vous avez besoin
Starting with the corners, gently pull the rubber cover off of the device.
Using the T-6 hexagonal screwdriver, unscrew the four 10mm #6 hex screws on the right side of the device.
Remove the handle from the device.
Unscrew the two screws on the left side of the device using the phillips #00 screwdriver.
One 5mm Phillips screw.
One 8mm Phillips screw.
Using a #000 Phillips Screwdriver, unscrew the four 0.8 cm Philips screws from each corner of the speaker you are replacing (eight 0.8 Philips screws total).
2 autres ont terminé cette réparation.
