Aller au contenu principal
Skullcandy Crusher Wireless Folding Hinge Replacement
Ce dont vous avez besoin
  1. Skullcandy Crusher Wireless Folding Hinge Replacement, Folding Hinge: étape 1, image 1 de 3 Skullcandy Crusher Wireless Folding Hinge Replacement, Folding Hinge: étape 1, image 2 de 3 Skullcandy Crusher Wireless Folding Hinge Replacement, Folding Hinge: étape 1, image 3 de 3
    • Extend and fold the hinge of the headphones you are trying to replace.
  2. Skullcandy Crusher Wireless Folding Hinge Replacement: étape 2, image 1 de 3 Skullcandy Crusher Wireless Folding Hinge Replacement: étape 2, image 2 de 3 Skullcandy Crusher Wireless Folding Hinge Replacement: étape 2, image 3 de 3
    • Remove two 14 mm Torx T6 screws on the underside of the headband.
  3. Skullcandy Crusher Wireless Folding Hinge Replacement: étape 3, image 1 de 3 Skullcandy Crusher Wireless Folding Hinge Replacement: étape 3, image 2 de 3 Skullcandy Crusher Wireless Folding Hinge Replacement: étape 3, image 3 de 3
    • Pry the speaker away from the headband with a slight force.
  4. Skullcandy Crusher Wireless Folding Hinge Replacement: étape 4, image 1 de 3 Skullcandy Crusher Wireless Folding Hinge Replacement: étape 4, image 2 de 3 Skullcandy Crusher Wireless Folding Hinge Replacement: étape 4, image 3 de 3
    • Remove two 5 mm Phillips #1 screws on the underside of the headband.
  5. Skullcandy Crusher Wireless Folding Hinge Replacement: étape 5, image 1 de 2 Skullcandy Crusher Wireless Folding Hinge Replacement: étape 5, image 2 de 2
    • Remove the top plastic part of the hinge.
9 autres ont terminé cette réparation.
Val
Membre depuis le 03/31/22
1 080 Réputation
6 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-33, Gurgel Spring 2022 Membre de l'équipe UMass Dartmouth, Team 1-33, Gurgel Spring 2022
UMASSD-GURGEL-S22S1G33
1 membre
12 tutoriels rédigés
5 commentaires
Hello. Any idea where can i buy the folding hinge from? thx!
Liviu - Réponse
Hi, Like the explanation but can you tell me where to buy tge folding hinge?
Menno de Gier - Réponse
I'm 3D printing these here https://www.ebay.co.uk/itm/364153346438
Stronger than original.
Eatfire - Réponse
This is my alternative solution, albeit a temporary one. Sharing for people that end up here through search engines.
I figured out a temporary fix. I am posting this for others arriving here from search engines and the like. I assume OP's problem has long been solved. My fix is based on somebody else's fix.
I have 3D printed parts on the way, but my 'design' may actually press down on my ears better than the original. 🤔
What you'll need:
-Tie rip 2 mm
-Tie rip 4 mm
-Drill + 1,5 mm drillbit for metal
-Strong thin elastic.
-Pliers (for making sure the tierips are real tight.)
https://guide-images.cdn.ifixit.com/igi/...
Cus7od35 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 15
7 derniers jours : 65
30 derniers jours : 213
Total : 8,806
