Aller au contenu principal
Skullcandy Mix Master DJ Mylar Driver Replacement
Ce dont vous avez besoin
  1. Skullcandy Mix Master DJ Mylar Driver Replacement, Mylar Driver: étape 1, image 1 de 3 Skullcandy Mix Master DJ Mylar Driver Replacement, Mylar Driver: étape 1, image 2 de 3 Skullcandy Mix Master DJ Mylar Driver Replacement, Mylar Driver: étape 1, image 3 de 3
    • With the plastic opening tool, separate the padded ear cup from the main speaker component.
    • Make sure to fold the ear cup inward to avoid getting in the way of the opposite side.
  2. Skullcandy Mix Master DJ Mylar Driver Replacement: étape 2, image 1 de 1
    • Using your screw driver, remove the six Philips 2mm screws located on the chrome ring.
  3. Skullcandy Mix Master DJ Mylar Driver Replacement: étape 3, image 1 de 2 Skullcandy Mix Master DJ Mylar Driver Replacement: étape 3, image 2 de 2
    • Using your screw driver, remove the four 3mm Phillips screws located on the grey speaker.
    • Remove the driver from the gray speaker assembly.
    • Carefully remove the driver assembly since there are wires connected to the headphone jack, headband, and mute button.
  4. Skullcandy Mix Master DJ Mylar Driver Replacement: étape 4, image 1 de 2 Skullcandy Mix Master DJ Mylar Driver Replacement: étape 4, image 2 de 2
    • Using your screw driver, remove the two 2mm Phillips screws located on the circuit panel of the audio jack.
    • Carefully separate the jack from the ear cup casing.
    • If you are working on the right ear cup, the mute button circuit board may be difficult to remove.
  5. Skullcandy Mix Master DJ Mylar Driver Replacement: étape 5, image 1 de 2 Skullcandy Mix Master DJ Mylar Driver Replacement: étape 5, image 2 de 2
    • The Mylar driver is connected to several small circuit boards by soldered wires. It can only be removed by cutting the connecting wires.
    • Do not pull the driver away too fast since there are wires connecting the driver to the ear cup.
    • Soldering Guide: https://www.youtube.com/watch?v=urGB_IUX...
Sean Herlihy
Membre depuis le 03/30/15
117 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 1-3, Shastany Spring 2015 Membre de l'équipe UMass Dartmouth, Team 1-3, Shastany Spring 2015
UMASSD-SHASTANY-S15S1G3
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 11
Total : 1,527
