Aller au contenu principal
Skullcandy UPROCK Earpiece Wiring Replacement
Ce dont vous avez besoin
  1. Skullcandy UPROCK Earpiece Wiring Replacement, Earpiece Wiring: étape 1, image 1 de 1
    • Remove the cushion from the ear piece.
  2. Skullcandy UPROCK Earpiece Wiring Replacement: étape 2, image 1 de 2 Skullcandy UPROCK Earpiece Wiring Replacement: étape 2, image 2 de 2
    • Use a Phillips #0 to unscrew three 3.4MM screws from the earpiece.
  3. Skullcandy UPROCK Earpiece Wiring Replacement: étape 3, image 1 de 2 Skullcandy UPROCK Earpiece Wiring Replacement: étape 3, image 2 de 2
    • Find the wires connected to the speaker and check if they are intact.
  4. Skullcandy UPROCK Earpiece Wiring Replacement: étape 4, image 1 de 1
    • If a wire is broken, use a soldering iron to reattach it to the speaker.
    • To learn how to solder, read the Comment souder et dessouder des connexions Guide.
    • After soldering is complete, the wires should look like this.
Ligne d'arrivée
2 autres ont terminé cette réparation.
Kayla Robinson
Membre depuis le 03/24/15
260 Réputation
2 tutoriels rédigés
Équipe
University of Alabama, Team 1-2, Naidoo Spring 2015 Membre de l'équipe University of Alabama, Team 1-2, Naidoo Spring 2015
UA-NAIDOO-S15S1G2
5 membres
4 tutoriels rédigés
Un commentaire
my jack is broken can i get a whole new wire so i could do soldering or can i use any other wire. if i use any other wire can i connect in btw of old wire coz i removed the jack by cutting the wire from jack or do i have to do soldering from beginning form inside.
Anuj Verma - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 16
Total : 6,256
