Aller au contenu principal
Sky Thunder HD 8500WH Gear Replacement
Ce dont vous avez besoin
  1. Sky Thunder HD 8500WH Gear Replacement, Rotor Blade: étape 1, image 1 de 3 Sky Thunder HD 8500WH Gear Replacement, Rotor Blade: étape 1, image 2 de 3 Sky Thunder HD 8500WH Gear Replacement, Rotor Blade: étape 1, image 3 de 3
    • Place the drone with the top side facing up.
    • Remove the blade cover.
    • Remove the rotor blade.
  2. Sky Thunder HD 8500WH Gear Replacement, Lockstitch: étape 2, image 1 de 2 Sky Thunder HD 8500WH Gear Replacement, Lockstitch: étape 2, image 2 de 2
    • Unscrew the 1cm screw holding in the blade lockstitch with the Phillips 0 Screwdriver.
    • Remove the blade lockstitch.
  3. Sky Thunder HD 8500WH Gear Replacement, Lower and Upper Body: étape 3, image 1 de 3 Sky Thunder HD 8500WH Gear Replacement, Lower and Upper Body: étape 3, image 2 de 3 Sky Thunder HD 8500WH Gear Replacement, Lower and Upper Body: étape 3, image 3 de 3
    • Lay down the drone so the battery side is facing up.
    • Unscrew all 5 .8cm screws on each arm of the drone with the Phillips 0 Screwdriver.
    • Repeat previous bullet for each arm (20 screws in total).
  4. Sky Thunder HD 8500WH Gear Replacement: étape 4, image 1 de 2 Sky Thunder HD 8500WH Gear Replacement: étape 4, image 2 de 2
    • Using a bit of force, gently pull apart the lower and upper bodies.
    • Keep going until both parts are completely separated.
  5. Sky Thunder HD 8500WH Gear Replacement, Gear: étape 5, image 1 de 2 Sky Thunder HD 8500WH Gear Replacement, Gear: étape 5, image 2 de 2
    • Find the gear mechanism at the end of one of the drone arms.
    • Unscrew the two front .8cm screws with the Phillips 0 Screwdriver.
  6. Sky Thunder HD 8500WH Gear Replacement: étape 6, image 1 de 2 Sky Thunder HD 8500WH Gear Replacement: étape 6, image 2 de 2
    • Remove the white spacer.
    • Remove the red spacer.
  7. Sky Thunder HD 8500WH Gear Replacement: étape 7, image 1 de 1
    • Pull the gear out from the bottom of the holding mechanism.
Nicholas Jones
Membre depuis le 09/25/17
672 Réputation
5 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 153
