Aller au contenu principal
Sliding Folding Door Hinge Replacement
Ce dont vous avez besoin
  1. Sliding Folding Door Hinge Replacement, Hinge: étape 1, image 1 de 1
    • Using the Phillips #2 screwdriver, remove any remaining old screws and hinges that you want to replace.
    • Counterclockwise will remove the screws.
  2. Sliding Folding Door Hinge Replacement: étape 2, image 1 de 1
    • Screws come loose when the holes become too large for the screws. If necessary, drill new holes into the door.
    • In this case, the top two holes were no longer usable, so we created more underneath the bottom holes.
  3. Sliding Folding Door Hinge Replacement: étape 3, image 1 de 2 Sliding Folding Door Hinge Replacement: étape 3, image 2 de 2
    • One by one, use the screwdriver to place the new screws.
    • The screws shouldn't be too tight. Be sure that the hinge is loose enough to rotate while placing the other screws.
    • Tighten all screws best you can with the hand held screwdriver.
  4. Sliding Folding Door Hinge Replacement: étape 4, image 1 de 1
    • The new hinge and screws should be in place now. If you would like, you can patch up the old holes and paint over them.
Torianna Marasco
Membre depuis le 03/15/21
130 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 10
Total : 806
