Introduction
This guide will help people who may be trying to replace their sliding glass door rollers. You will need a screw driver and a set of new door rollers to perform this task. It is also handy to have someone there to help you get the doors off the track.
Ce dont vous avez besoin
Find the screw on the bottom of the door. Adjust the rollers to the highest setting to lift the rollers off track.
Sliding glass door rollers go through wear and tear, which can make the doors difficult to use. After completing this guide your doors should be rocking and rolling like new!
2 autres ont terminé cette réparation.
Un commentaire
Step 1: Find the screw on the bottom of the door. Adjust the rollers to the highest setting to lift the rollers off track.
Probably not. The rollers are adjusted to the LOWEST setting. That gives the most clearance to lift the door off the track. Set it to 'highest' and the rollers will likely hang up on the track when you try to lift the door OFF the track.
What is this point of view based on? Having done it half a dozen times.
