Aller au contenu principal
Slingbox SOLO DC Power Connector Replacement
Ce dont vous avez besoin
  1. Slingbox SOLO DC Power Connector Replacement, Motherboard: étape 1, image 1 de 1
    • Use the plastic opening tool to remove the four rubber pads from the bottom of the device.
  2. Slingbox SOLO DC Power Connector Replacement: étape 2, image 1 de 3 Slingbox SOLO DC Power Connector Replacement: étape 2, image 2 de 3 Slingbox SOLO DC Power Connector Replacement: étape 2, image 3 de 3
    • The Slingbox has four black 5mm screws, one on each corner of the case.
    • Remove the four black 5mm screws using the PH1 screwdriver.
    • Gently pull and separate the two case covers.
  3. Slingbox SOLO DC Power Connector Replacement: étape 3, image 1 de 3 Slingbox SOLO DC Power Connector Replacement: étape 3, image 2 de 3 Slingbox SOLO DC Power Connector Replacement: étape 3, image 3 de 3
    • The motherboard has five silver 5.5mm screws connecting it to the base of the Slingbox.
    • Remove the five silver screws on the motherboard using the PH1 screwdriver.
    • Gently slide and separate the motherboard from the base.
  4. Slingbox SOLO DC Power Connector Replacement, DC Power Connector: étape 4, image 1 de 1
    • Do not touch the heated tip of the soldering iron.
    • Check this guide out to learn how to use a soldering iron.
    • Desolder all three lead prongs.
    • Gently pull the DC power connector from the motherboard.
To reassemble your device, follow the instructions in reverse order.
Nitin Muralidhar
Membre depuis le 07/18/16
222 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team 2-2, Harley SU 2016 Membre de l'équipe IUPUI, Team 2-2, Harley SU 2016
IUPUI-HARLEY-SU16S2G2
5 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 9
Total : 287
