Aller au contenu principal
Small Engine Recoil Starter Replacement
Ce dont vous avez besoin
  1. Small Engine Recoil Starter Replacement, Recoil Starter: étape 1, image 1 de 1
    • To begin the repair remove the protective casing. (This removal may vary with different lawnmowers.)
  2. Small Engine Recoil Starter Replacement: étape 2, image 1 de 1
    • Locate the recoil housing cap.
  3. Small Engine Recoil Starter Replacement: étape 3, image 1 de 1
    • Carefully remove the housing cap. (Removal may vary)
  4. Small Engine Recoil Starter Replacement: étape 4, image 1 de 1
    • After removing the recoil, unscrew the cap that holds the pulley to the recoil starter housing.
  5. Small Engine Recoil Starter Replacement: étape 5, image 1 de 1
    • Untie the knot in the rope and slide it out of the housing.
  6. Small Engine Recoil Starter Replacement: étape 6, image 1 de 1
    • With this particular model there is a middle lock piece. Use a socket wrench to unscrew and release the coil.
  7. Small Engine Recoil Starter Replacement: étape 7, image 1 de 1
    • Once unscrewed, remove the metal piece which releases the tension on the coil.
  8. Small Engine Recoil Starter Replacement: étape 8, image 1 de 1
    • At this point add the new coil to the housing base. Snap the coil into position where the old on was.
5 autres ont terminé cette réparation.
James Marmaud
Membre depuis le 03/20/17
276 Réputation
1 tutoriel rédigé
Équipe
Missouri Western, Team S40-G16, Kunkel Spring 2017 Membre de l'équipe Missouri Western, Team S40-G16, Kunkel Spring 2017
MWSU-KUNKEL-S17S40G16
2 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 49
Total : 2,780
