Introduction
Sometimes the Ion's eye vision board is damaged and may need replacing. While working on the Ion, the user should be aware of the pressure due to air inside the gun. Pressurized air can be forceful, causing particles to be ejected from the gun into your eyes and/or skin. When air bubbles enter the bloodstream, they can block blood vessels and cause embolisms. To avoid this, make sure to point the gun in a safe direction when de-gasing the Ion.
Ce dont vous avez besoin
Turn the gun on by pressing the power button until the red light blinks.
Turn vision mode off by pressing the power button again.
Remove the four 8mm screws on each side of the gun's grip using a Phillips #2 screwdriver.
Remove the front and rear 1" screws on the gun's grip frame using a 3/32" Allen Wrench.
Remove the gun's green vision eye board by gently pulling it out using your index finger and thumb.
