Aller au contenu principal
Snapfon ez One Motherboard Replacement
Ce dont vous avez besoin
  1. Snapfon ez One Motherboard Replacement, Remove the battery cover: étape 1, image 1 de 1
    • Turn off the phone to prevent data loss.
    • Press and slide the battery out to remove it.
    • Picture rights belong to Snapfon®. Picture is used for educational purposes only. No copyright infringement intended.
  2. Snapfon ez One Motherboard Replacement, Remove the battery: étape 2, image 1 de 1
    • Pry the battery out with your thumb or the iFixit opening tool.
    • Make sure to properly dispose of the old battery at a recycling center.
  3. Snapfon ez One Motherboard Replacement, Removing the plastic inserts: étape 3, image 1 de 2 Snapfon ez One Motherboard Replacement, Removing the plastic inserts: étape 3, image 2 de 2
    • Remove the four rubber inserts from the screw holes using a pair of tweezers.
  4. Snapfon ez One Motherboard Replacement, Remove the shield screws: étape 4, image 1 de 3 Snapfon ez One Motherboard Replacement, Remove the shield screws: étape 4, image 2 de 3 Snapfon ez One Motherboard Replacement, Remove the shield screws: étape 4, image 3 de 3
    • Remove the four 3.1mm screws in the corners with a Phillips #00 screwdriver.
  5. Snapfon ez One Motherboard Replacement, Separate the case: étape 5, image 1 de 3 Snapfon ez One Motherboard Replacement, Separate the case: étape 5, image 2 de 3 Snapfon ez One Motherboard Replacement, Separate the case: étape 5, image 3 de 3
    • Separate the front case from the back case.
    • Remove the metal bumper from the front case’s perimeter.
  6. Snapfon ez One Motherboard Replacement, Remove the volume slider: étape 6, image 1 de 1
    • Pry the volume slider button out with tweezers.
    • The volume slider button may fall out during the separation of the front and back cases. This is OK.
  7. Snapfon ez One Motherboard Replacement, Remove the motherboard: étape 7, image 1 de 3 Snapfon ez One Motherboard Replacement, Remove the motherboard: étape 7, image 2 de 3 Snapfon ez One Motherboard Replacement, Remove the motherboard: étape 7, image 3 de 3
    • Separate the circuit board from the inside of the back case by prying between them with the opening tool.
    • The last picture is a view of the back of the circuit board.
John Bender
Membre depuis le 03/26/14
818 Réputation
8 tutoriels rédigés
Équipe
Clemson, Team 6-5, Benson Spring 2014 Membre de l'équipe Clemson, Team 6-5, Benson Spring 2014
CLEM-BENSON-S14S6G5
3 membres
16 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 6
Total : 210
