Aller au contenu principal
Snowboard Binding Replacement
Ce dont vous avez besoin
  1. Snowboard Binding Replacement, Binding: étape 1, image 1 de 3 Snowboard Binding Replacement, Binding: étape 1, image 2 de 3 Snowboard Binding Replacement, Binding: étape 1, image 3 de 3
    • Release the binding straps by lifting up on the buckle and pulling towards the direction of the end of the ladder.
    • Not all binding straps will release the same way. If you are having trouble releasing your binding straps, please refer to your owner's manual.
  2. Snowboard Binding Replacement: étape 2, image 1 de 2 Snowboard Binding Replacement: étape 2, image 2 de 2
    • Move the straps and the highback plate out of the way in order to have clear access to the foot pad screw.
    • The highback plate is the vertical support plate located on the heel side of the binding.
  3. Snowboard Binding Replacement: étape 3, image 1 de 2 Snowboard Binding Replacement: étape 3, image 2 de 2
    • Use a #2 Phillips screwdriver to remove the panhead, 10mm wide, M4 x 12mm screw located in the middle of the foot pad.
  4. Snowboard Binding Replacement: étape 4, image 1 de 3 Snowboard Binding Replacement: étape 4, image 2 de 3 Snowboard Binding Replacement: étape 4, image 3 de 3
    • Use a #2 Phillips screwdriver to remove the four ovalhead M6 x 12mm screws that attach the base plate of the binding to the board.
    • Lift or slide the binding off the board and set the screws aside.
2 autres ont terminé cette réparation.
Loren Sunding
Membre depuis le 01/14/14
118 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 17-4, Forte Winter 2014 Membre de l'équipe Cal Poly, Team 17-4, Forte Winter 2014
CPSU-FORTE-W14S17G4
5 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 13
30 derniers jours : 44
Total : 13,495
