Aller au contenu principal
Snowboard Binding Strap Replacement
Ce dont vous avez besoin
  1. Snowboard Binding Strap Replacement, Binding: étape 1, image 1 de 3 Snowboard Binding Strap Replacement, Binding: étape 1, image 2 de 3 Snowboard Binding Strap Replacement, Binding: étape 1, image 3 de 3
    • Release the binding straps by lifting up on the buckle and pulling towards the direction of the end of the ladder.
    • Not all binding straps will release the same way. If you are having trouble releasing your binding straps, please refer to your owner's manual.
  2. Snowboard Binding Strap Replacement: étape 2, image 1 de 2 Snowboard Binding Strap Replacement: étape 2, image 2 de 2
    • Move the straps and the highback plate out of the way in order to have clear access to the foot pad screw.
    • The highback plate is the vertical support plate located on the heel side of the binding.
  3. Snowboard Binding Strap Replacement: étape 3, image 1 de 2 Snowboard Binding Strap Replacement: étape 3, image 2 de 2
    • Use a #2 Phillips screwdriver to remove the panhead, 10mm wide, M4 x 12mm screw located in the middle of the foot pad.
  4. Snowboard Binding Strap Replacement: étape 4, image 1 de 3 Snowboard Binding Strap Replacement: étape 4, image 2 de 3 Snowboard Binding Strap Replacement: étape 4, image 3 de 3
    • Use a #2 Phillips screwdriver to remove the four ovalhead M6 x 12mm screws that attach the base plate of the binding to the board.
    • Lift or slide the binding off the board and set the screws aside.
  5. Snowboard Binding Strap Replacement, Binding Strap: étape 5, image 1 de 3 Snowboard Binding Strap Replacement, Binding Strap: étape 5, image 2 de 3 Snowboard Binding Strap Replacement, Binding Strap: étape 5, image 3 de 3
    • Use a 5.5mm flathead screwdriver to anchor the backing bracket located on the inside of the binding.
    • Using a Phillips #2 screwdriver, unscrew the countersunk ovalhead M4 x 16mm screw connecting the heel strap ladder to the binding.
  6. Snowboard Binding Strap Replacement: étape 6, image 1 de 2 Snowboard Binding Strap Replacement: étape 6, image 2 de 2
    • Unscrew the 10mm long thumb screw connecting the heel strap with its binding connector.
    • Pull the heel strap apart from its binding connector.
  7. Snowboard Binding Strap Replacement: étape 7, image 1 de 3 Snowboard Binding Strap Replacement: étape 7, image 2 de 3 Snowboard Binding Strap Replacement: étape 7, image 3 de 3
    • Using a Phillips #2 screwdriver, locate and unscrew the countersunk ovalhead M4 x 16mm screw holding the heel strap connector to the binding.
  8. Snowboard Binding Strap Replacement: étape 8, image 1 de 2 Snowboard Binding Strap Replacement: étape 8, image 2 de 2
    • Flip the binding so that the bottom is accessible.
    • Using your hands, pry off the plastic bottom covering starting at the toe end.
    • The bottom may still remain attached on the heel edge. There is no need to completely remove it.
  9. Snowboard Binding Strap Replacement: étape 9, image 1 de 3 Snowboard Binding Strap Replacement: étape 9, image 2 de 3 Snowboard Binding Strap Replacement: étape 9, image 3 de 3
    • Remove the corner foam coverings by grabbing one edge and lifting up.
    • Slide out the toe strap ladder.
  10. Snowboard Binding Strap Replacement: étape 10, image 1 de 3 Snowboard Binding Strap Replacement: étape 10, image 2 de 3 Snowboard Binding Strap Replacement: étape 10, image 3 de 3
    • Using a Phillips #2 screwdriver, unscrew the button head M4 x 10mm screw holding the toe strap with its connector.
    • Slide the toe strap off of the toe strap connector.
  11. Snowboard Binding Strap Replacement: étape 11, image 1 de 2 Snowboard Binding Strap Replacement: étape 11, image 2 de 2
    • Turn the binding on its side and slide out the toe strap connector.
Robert Torres
Membre depuis le 01/14/14
214 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 17-4, Forte Winter 2014 Membre de l'équipe Cal Poly, Team 17-4, Forte Winter 2014
CPSU-FORTE-W14S17G4
5 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 21
30 derniers jours : 69
Total : 40,078
