Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Soda Trend Deluxe Bottle Connector Replacement
Ce dont vous avez besoin
  1. Soda Trend Deluxe Bottle Connector Replacement, Remove cartridge: étape 1, image 1 de 3 Soda Trend Deluxe Bottle Connector Replacement, Remove cartridge: étape 1, image 2 de 3 Soda Trend Deluxe Bottle Connector Replacement, Remove cartridge: étape 1, image 3 de 3
    • Remove back panel.
    • Remove CO2 cartridge.
    Demander à FixBot
    Ajouter un commentaire
  2. Soda Trend Deluxe Bottle Connector Replacement, Remove CO2 cartridge lever: étape 2, image 1 de 2 Soda Trend Deluxe Bottle Connector Replacement, Remove CO2 cartridge lever: étape 2, image 2 de 2
    • Flip the device on its head.
    • Move CO2 cartridge lever to the very right and squish it together to unhook it first on the right, then on the left.
    • Pull lever down and unhook in the back.
    Demander à FixBot
  3. Soda Trend Deluxe Bottle Connector Replacement, Open Topcover: étape 3, image 1 de 2 Soda Trend Deluxe Bottle Connector Replacement, Open Topcover: étape 3, image 2 de 2
    • With a spudger or knife find the section on the right side between the top cover and the outer shell where the spudger slips in.
    • Carefully, leverage the top cover from the internal hooks until all six hooks are free and you can remove the top cover.
    Demander à FixBot
  4. Soda Trend Deluxe Bottle Connector Replacement, Remove top casing: étape 4, image 1 de 1
    • Remove four PH2 screws that hold the top casing.
    • Remove the top casing.
    Demander à FixBot
  5. Soda Trend Deluxe Bottle Connector Replacement, Remove rear lever screws: étape 5, image 1 de 1
    • Remove the two outer PH2 screws holding the lever in the back section.
    Demander à FixBot
  6. Soda Trend Deluxe Bottle Connector Replacement, Remove front lever screws: étape 6, image 1 de 1
    • Remove the four PH2 screws that hold the black lever section in the front.
    Demander à FixBot
  7. Soda Trend Deluxe Bottle Connector Replacement: étape 7, image 1 de 2 Soda Trend Deluxe Bottle Connector Replacement: étape 7, image 2 de 2
    • Remove the lever segment from the top.
    • Take care not to loose the central safety pin.
    Demander à FixBot
  8. Soda Trend Deluxe Bottle Connector Replacement, Remove bottle connector: étape 8, image 1 de 2 Soda Trend Deluxe Bottle Connector Replacement, Remove bottle connector: étape 8, image 2 de 2
    • Remove the 4 PH2 screws at the bottom of the bottle connector.
    • Remove 6 PH2 screws at the top of the bottle connector.
    • Replace bottle connector.
    Demander à FixBot
Tim K
Membre depuis le 10/22/25
197 Réputation
1 tutoriel rédigé
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 36
Total : 165
