Aller au contenu principal
Sol Republic Deck Battery Replacement
Ce dont vous avez besoin
  1. Sol Republic Deck Battery Replacement, Battery: étape 1, image 1 de 1
    • With plastic spudger wedge in between the top and bottom casings to force sepearation . Exposing the inside components of the Republic Deck.
  2. Sol Republic Deck Battery Replacement: étape 2, image 1 de 1
    • Use the screwdriver to unscrew 2 3.63mm Phillips #0 screws securing the plastic plate.
  3. Sol Republic Deck Battery Replacement: étape 3, image 1 de 1
    • Remove ribbon cable from the circuit board.
  4. Sol Republic Deck Battery Replacement: étape 4, image 1 de 2 Sol Republic Deck Battery Replacement: étape 4, image 2 de 2
    • Unscrew five 3.6 mm Phillips #0 screws securing the circuit board.
    • The ribbon cables are adhesive attached to the case, use tweezers to VERY carefully pick them up. They will then lift up with the circuit board. Or desolder them at the bottom to separate from the circuit board.
    • Melt the solder with an iron and used the tweezers to pull the wire upright.
    • You can pull the circuit board up and away from the wires once the wires are pointed up.
  5. Sol Republic Deck Battery Replacement: étape 5, image 1 de 1
    • Unscrew eighteen 6.2 mm Phillips #0 screws and lift the black plastic plate from the case.
  6. Sol Republic Deck Battery Replacement: étape 6, image 1 de 3 Sol Republic Deck Battery Replacement: étape 6, image 2 de 3 Sol Republic Deck Battery Replacement: étape 6, image 3 de 3
    • Unscrew both 3.6 mm Phillips #0 screws holding the battery case to the back of the plastic plate.
    • Remove the battery from the battery case.
    • Original battery is ICR18650-30A. Its rated for 3000mAh, 6A continuous (2 C-rate).
    Make sure the replacement battery can put out 6 amps continuous or more.
    Michael Iarussi - Réponse
4 autres ont terminé cette réparation.
Ross Bolton
Membre depuis le 03/21/17
133 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S3-G1, Baechle Spring 2017 Membre de l'équipe IUPUI, Team S3-G1, Baechle Spring 2017
IUPUI-BAECHLE-S17S3G1
3 membres
3 tutoriels rédigés
10 commentaires
I appreciate the battery replacement for the deck,but what about battery replacement
For the deck ultra
chai4i - Réponse
What type of battery is it?
Peter Perez - Réponse
It's just a regular lithium ion 18650 battery 3.7v 3200-3500 mah. The deck ultra uses 2 of these
Aaron Linn - Réponse
The wires which are blue and purple are connected to battery body if im not wrong
vineeth m -
After changing the battery my device is not switching on. Please help. I connected the charger the battery is charging... showing red.
vineeth m - Réponse
After replacing the battery i am facing this issue..
vineeth m - Réponse
Sounds was not clayer and battery is ded
Sandeep Maher - Réponse
My solo deck is not good sound was not well and battery is not charge
My deck is not responding for charging and not getting switch on all in sudden.
Any suggestions please.
இயற்கை வாழ்வியல் - Réponse
The max charge voltage of ICR18650-30A is 4.35V and most 4.35V Li-ion batteries including this one have been discontinued. I’m not sure if a 4.2V battery can be used without safety issues even if it’s working. I wonder if Deck is set to charge at 4.2V or 4.35V.
patrick - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 54
Total : 7,825
