Aller au contenu principal
Sol Republic Deck Bluetooth Button Replacement
Ce dont vous avez besoin
  1. Sol Republic Deck Bluetooth Button Replacement, Bluetooth Button: étape 1, image 1 de 1
    • With plastic spudger wedge in between the top and bottom casings to force sepearation . Exposing the inside components of the Republic Deck.
  2. Sol Republic Deck Bluetooth Button Replacement: étape 2, image 1 de 1
    • Use the screwdriver to unscrew two 3.6mm Phillips #0 screws securing the plastic plate.
  3. Sol Republic Deck Bluetooth Button Replacement: étape 3, image 1 de 1
    • Remove the ribbon cable from the circuit board.
  4. Sol Republic Deck Bluetooth Button Replacement: étape 4, image 1 de 1
    • Plug in de-soldering kit and wait 3 minutes for the solder to heat up.
    • Use the tip of your soldering iron to heat the old solder unit and apply until it melts.
    • Remove speaker wires connecting the speaker to the circuit board.
  5. Sol Republic Deck Bluetooth Button Replacement: étape 5, image 1 de 1
    • Unscrew five 3.6 mm Phillips #0 screws securing the circuit board.
  6. Sol Republic Deck Bluetooth Button Replacement: étape 6, image 1 de 1
    • Unscrew fifteen 6.2mm Phillips #0 screws and lift the black plastic plate from the case.
  7. Sol Republic Deck Bluetooth Button Replacement: étape 7, image 1 de 2 Sol Republic Deck Bluetooth Button Replacement: étape 7, image 2 de 2
    • Remove the three 3.6mm Phillips #0 screws.
    • Remove the circuit board containing the BlueTooth button.
Jonathan Holtman
Membre depuis le 03/20/17
368 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S3-G1, Baechle Spring 2017 Membre de l'équipe IUPUI, Team S3-G1, Baechle Spring 2017
IUPUI-BAECHLE-S17S3G1
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 3
Total : 546
