Introduction
Use this guide to replace the circuit board that connects to the LEDs in the LED lantern.
Ce dont vous avez besoin
Flip the lantern upside down and unscrew the 4 phillips head screws on the base and remove the base plate.
To disassemble the main body, grip the lantern so that the front half of the body with the power button on it is in your right hand and the back half with the hand crank is in your left.
Pinch the front half of the body on both sides with your thumb and index finger just below the first extruding rim of the front plate while simultaneously pulling the back half away. This may take some effort to do.
Locate the LED board. It is located in the base of the globe, with the LEDs extending up inside the globe.
Trace the wires coming from the LED board to the main board. Pull out the white clip connecting the wires from the LED board from the socket on the main board. This will sever the electrical connection between the LED board and the rest of the lantern.
Grip the globe of the lantern and turn the top lid of the lantern counter-clockwise so it can be removed.
Place the lid, with the solar panel down, on the table. Unsolder the two wires connected to the solar panel.
Feed wires from solar panel down the main shaft running through the middle of the globe.
Making sure both halves of the lantern are detached from the globe, pull LED board out of the base of the globe. Be careful not to damage any LED connected to the board.
Replace with new board, making sure grooves on the new LED board align with corresponding tabs in the base of the globe. This is to ensure the LEDs fit into the base of the globe.
Feed the two disconnected wires from the white clip back up through the main shaft of the globe to the top portion of the lantern where the lid attaches.
Solder the new wires to the base of the solar panel.
Reattach the lid to top of the lantern by aligning grooves and turning clockwise.
