Introduction
This particular camera stopped working for me, so I decided to take it apart.
This is not a logical way to take apart this device. I plan to make some repair guides for this model in the future.
Ce dont vous avez besoin
Here, I've got my hands on a camera that no longer works.
Seeing that I can't use it for anything useful, I decided to take it apart, because why not?
Time to start the teardown! Let's start by removing the bottom cover.
This revealed almost nothing about the insides of the camera, but did reveal that the rest the case (minus the silver plastic top cover) is split into two halves.
I spot screws! Disassembling the battery door revealed some springs, but that's just about it.
Breakthrough! I discovered that the top cover pops off almost as easily as the bottom cover (held on by just a few clips once the screws were removed).
The back case simply popped out of place, revealing several components inside.
Camera, you're first! Removing and disassembling the camera module revealed that the component itself is tiny compared to the rest of the device.
The camera, labelled OV8865AF-FPC-V10-LF, is capable of taking photos at 3264 x 2448 (8 megapixels) at 30FPS. It can also record video at 1080p at 30FPS or half the resolution for double the FPS.
Removing the flash cover revealed more screws to remove the flash module, which is soldered to the logic board with two wires.
I was disappointed to learn that removing this metal plate, which turned out to be a weight, didn't reveal any screws or components.
The microphone popped out with ease, but the speaker is glued in with a gasket of adhesive. While the adhesive is light, the speaker's positioning makes it more difficult to remove than it would've been if it could've been pried straight out.
Time to remove the front cover! This revealed several buttons along with the screen.
I removed a screw near the bottom-left of the display that seemed to only hold down a small metal cover.
Unplugging the display cable requires the black tabs to be pulled out pulling out the cable.
Removing the screws around the display frame let the logic board free.
Some parts fell off while I was disassembling the device. The first picture shows the tiny metal cover and the battery locking mechanism, and the others are of the hot shoe that was soldered to the motherboard.
Taking apart the back case separates some plastic bits from a gasket and the glass. (Yes, it's real glass.)
Finally! The logic board!
On the front:
2301 LUL083 PM230102 or 2301-EUL083 PM230102- probably a microcontroller
Puya PZS032SH 2KITA20, probably a flash memory chip
JL5001A 2101-BXA A1769G
On the back:
Not much except for the screen connector and buttons
