Aller au contenu principal
Sonos Bridge Ethernet Port Replacement
Ce dont vous avez besoin
  1. Sonos Bridge Ethernet Port Replacement, Ethernet Port: étape 1, image 1 de 1
    • The rubber bottom is glued on, meaning it can be easily pried off using the metal spudger.
    • You may have to pry from multiple locations.
  2. Sonos Bridge Ethernet Port Replacement: étape 2, image 1 de 3 Sonos Bridge Ethernet Port Replacement: étape 2, image 2 de 3 Sonos Bridge Ethernet Port Replacement: étape 2, image 3 de 3
    • There is one screw in each corner of the base for a total of four screws.
    • Remove each screw using the Phillips 1 screwdriver.
    • The four screws are each 0.9 cm long.
    • The screws are small, so be careful to not lose them.
  3. Sonos Bridge Ethernet Port Replacement: étape 3, image 1 de 2 Sonos Bridge Ethernet Port Replacement: étape 3, image 2 de 2
    • Use the metal spudger to pry out the plastic bottom.
    • Alternatively, the casing can be lightly tapped on a table (base down) to drop the bottom out of the casing.
  4. Sonos Bridge Ethernet Port Replacement: étape 4, image 1 de 2 Sonos Bridge Ethernet Port Replacement: étape 4, image 2 de 2
    • Pry out the circuit board.
    • Place the metal spudger under the board on the side opposite the two ports.
    • The board can then be easily wiggled out of the casing.
    • This should NOT require significant force.
  5. Sonos Bridge Ethernet Port Replacement: étape 5, image 1 de 3 Sonos Bridge Ethernet Port Replacement: étape 5, image 2 de 3 Sonos Bridge Ethernet Port Replacement: étape 5, image 3 de 3
    • Locate the Ethernet port on the circuit board, shown with the red box in the first image.
    • Locate the solders attached to the Ethernet port.
    • Use the soldering iron to undo the solders.
    • Carefully remove the Ethernet port by using the metal spudger and squeezing the black clips.
Brian Strader
Membre depuis le 11/07/17
201 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S3-G4, Harley Fall 2017 Membre de l'équipe IUPUI, Team S3-G4, Harley Fall 2017
IUPUI-HARLEY-F17S3G4
3 membres
2 tutoriels rédigés
Un commentaire
Hi could you tell me how to fix sonos zp100 bridge player internet port also where to get parts thanks
imranp7 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 14
Total : 1,703
