Introduction
This guide is for the replacement of the control panel and microphones for the Sonos One.
Disconnect all power cords.
  • Disconnect all power cords.
  • Remove the rubber foot and plastic screw guard on the bottom of the device using a plastic opening tool.
Ajouter un commentaire
Remove the four 10mm Torx T10 screws from the bottom of the speaker.
  • Remove the four 10mm Torx T10 screws from the bottom of the speaker.
  • Remove the bottom cover by squeezing the protective cover slightly while pushing up with your fingers.
  • The protective cover clip is very thin and deforms easily.
  • Remove the single 8mm Torx T10 screw and protective cover clip.
  • Slide the protective cover upwards to remove.
  • Use the pointed end of a spudger to remove the covers that hide the screws.
  • Remove the four 9mm Torx T8 screws from around the perimeter of the control panel.
  • With the front of the unit facing you, lift the control panel up using your thumbs.
  • There's a ribbon cable attaching the control panel to the speaker so work slowly.
  • Use a spudger to flip up the retaining flap on the control panel ribbon cable ZIF socket.
  • Pull the control panel ribbon cable out of its socket.
  • Pull the control panel away from the speaker to separate.
Marcus Glowa
Membre depuis le 14/02/2018
653 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S2-G1, Nance Spring 2018 Membre de l'équipe USF Tampa, Team S2-G1, Nance Spring 2018
USFT-NANCE-S18S2G1
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 63
Total : 207
