Introduction
If the screen on the Sonos Play 1 is dented, cracked or damaged, it may interfere with audio performance and may cause damage to the speakers. In order to prevent damage to the speakers and increase the devices performance, the exterior screen protecting the internal housing of the speakers will need to be replaced. This guide will demonstrate this process of removing the screen.
Ce dont vous avez besoin
Remove the rubber footing from the bottom of the device. Pry it up from one end using one of the plastic opening tools.
Once you pry open one end, use precision tweezers to remove rubber footing.
13 autres ont terminé cette réparation.
7 commentaires
Where can you purchase a replacement screen please? I dented mine by accident.
