Aller au contenu principal
Sonos Play 3 Front Speaker Panel Replacement
Conditions préalables uniquement
Ce tutoriel est uniquement destiné à être utilisé comme prérequis d'autres tutoriels. Il ne se suffit pas à lui-même.
Ce dont vous avez besoin
  1. Sonos Play 3 Front Speaker Panel Replacement, Front Speaker Panel: étape 1, image 1 de 2 Sonos Play 3 Front Speaker Panel Replacement, Front Speaker Panel: étape 1, image 2 de 2
    • Unscrew eight 1.5 inch Phillips #2 screws attaching the front speaker panel to the box.
    • Unscrew the single 1 inch Phillips #2 screw located on the left side of the panel. This may be hidden beneath the warranty void sticker that you'll want to remove.
    • Unscrew the single 3/4 inch Phillips #2 screw, which is the last thing holding the front panel to the casing.
  2. Sonos Play 3 Front Speaker Panel Replacement: étape 2, image 1 de 3 Sonos Play 3 Front Speaker Panel Replacement: étape 2, image 2 de 3 Sonos Play 3 Front Speaker Panel Replacement: étape 2, image 3 de 3
    • Remove the front panel carefully.
    • Note that there are two layers to the panel that should stay in their original order.
  3. Sonos Play 3 Front Speaker Panel Replacement: étape 3, image 1 de 2 Sonos Play 3 Front Speaker Panel Replacement: étape 3, image 2 de 2
    • Disconnect the front panel from the motherboard by gently reaching in and pushing the tab underneath the wire connector and pulling towards you.
  4. Sonos Play 3 Front Speaker Panel Replacement: étape 4, image 1 de 2 Sonos Play 3 Front Speaker Panel Replacement: étape 4, image 2 de 2
    • Gently remove the wireless card located at the bottom of the front speaker panel by pulling up and out with your index finger and thumb.
Christina Santini
Membre depuis le 04/14/16
1 350 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 25-6, Maness Spring 2016 Membre de l'équipe Cal Poly, Team 25-6, Maness Spring 2016
CPSU-MANESS-S16S25G6
4 membres
14 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 85
