Aller au contenu principal
Introduction
On the front face of the Sonos Play 3, there is a rectangular mesh screen. If this is damaged or there is dirt build up, it may affect the sound quality of the device. The exterior screen will need to be replaced or removed and cleaned in order to fix this problem. This guide will demonstrate how to remove the screen.
Pièces
Aucune pièce spécifiée.
  1. Insert a spudger along the edge of the screen and gently use it to pull the screen away from the casing. Slide the spudger along the length of the grill to detach all the clips holding it in place. Insert a spudger along the edge of the screen and gently use it to pull the screen away from the casing. Slide the spudger along the length of the grill to detach all the clips holding it in place.
    • Insert a spudger along the edge of the screen and gently use it to pull the screen away from the casing. Slide the spudger along the length of the grill to detach all the clips holding it in place.
  2. Fix Kits pour batterie de MacBook
    À partir de $69.99
    Buy Now
    À partir de $69.99
    Buy Now
  3. Gently pull the screen away from the body of the speaker, revealing the tweeter and two mid-range drivers behind it.
    • Gently pull the screen away from the body of the speaker, revealing the tweeter and two mid-range drivers behind it.
    • There may be a kind of black sticky adhesive holding the screen clips to the rest of the body; however, it was previously removed on our model.
Christina Santini
Membre depuis le 14/04/2016
1 098 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 25-6, Maness Spring 2016 Membre de l'équipe Cal Poly, Team 25-6, Maness Spring 2016
CPSU-MANESS-S16S25G6
4 membres
7 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 18
30 derniers jours : 78
Total : 2,317
