Aller au contenu principal
Sony α6000 Back Case Replacement
Ce dont vous avez besoin
  1. Sony α6000 Back Case Replacement, Battery: étape 1, image 1 de 2 Sony α6000 Back Case Replacement, Battery: étape 1, image 2 de 2
    • Begin by placing the camera facing upside down.
  2. Sony α6000 Back Case Replacement: étape 2, image 1 de 2 Sony α6000 Back Case Replacement: étape 2, image 2 de 2
    • Slide the notched locking bar on the battery compartment from LOCK to OPEN.
  3. Sony α6000 Back Case Replacement: étape 3, image 1 de 2 Sony α6000 Back Case Replacement: étape 3, image 2 de 2
    • Push the small blue bar horizontally off of the battery.
  4. Sony α6000 Back Case Replacement: étape 4, image 1 de 2 Sony α6000 Back Case Replacement: étape 4, image 2 de 2
    • Remove the battery.
  5. Sony α6000 Back Case Replacement, Back Case: étape 5, image 1 de 1
    • Position the camera with the bottom facing upwards and the lens facing away from you.
  6. Sony α6000 Back Case Replacement: étape 6, image 1 de 1
    • Once the battery is removed, use a Phillips #00 screwdriver to remove the three screws at the bottom of the battery compartment.
  7. Sony α6000 Back Case Replacement: étape 7, image 1 de 1
    • Use the Phillips #00 screwdriver to remove the screws located next to the camera strap.
    • There may be screws on either side by the camera strap mounts. If removing the screw on the left side doesn't sufficiently loosen the case, be sure to check for a screw on the other side before resorting to excessive force.
  8. Sony α6000 Back Case Replacement: étape 8, image 1 de 2 Sony α6000 Back Case Replacement: étape 8, image 2 de 2
    • Position the camera with the battery housing facing upwards.
    • Remove the two screws on the bottom of the camera using the Phillips #00 screwdriver.
  9. Sony α6000 Back Case Replacement: étape 9, image 1 de 1
    • Position the camera with the flash assembly facing upwards.
    • Remove the screw located underneath with a Phillips #00 screwdriver.
  10. Sony α6000 Back Case Replacement: étape 10, image 1 de 2 Sony α6000 Back Case Replacement: étape 10, image 2 de 2
    • Pull back the LCD screen.
    • Remove the three screws directly underneath using the Phillips #00 screwdriver.
  11. Sony α6000 Back Case Replacement: étape 11, image 1 de 1
    • Gently pop off the top case of the camera using your fingers or a plastic opening tool.
    • If using a plastic opening tool, ensure that the pressure is being applied to the plastic rather than the metal.
  12. Sony α6000 Back Case Replacement: étape 12, image 1 de 2 Sony α6000 Back Case Replacement: étape 12, image 2 de 2
    • Position the camera with the LCD screen facing upwards.
    • Gently remove the back case guiding it around the LCD screen.
2 autres ont terminé cette réparation.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 12
30 derniers jours : 65
Total : 1,580
