Aller au contenu principal
Sony Alpha NEX-3N LCD assembly Replacement
Ce dont vous avez besoin
  1. Sony Alpha NEX-3N LCD assembly Replacement, Getting Started: étape 1, image 1 de 2 Sony Alpha NEX-3N LCD assembly Replacement, Getting Started: étape 1, image 2 de 2
    • Remove battery and card
  2. Sony Alpha NEX-3N LCD assembly Replacement, Back Case 1: étape 2, image 1 de 3 Sony Alpha NEX-3N LCD assembly Replacement, Back Case 1: étape 2, image 2 de 3 Sony Alpha NEX-3N LCD assembly Replacement, Back Case 1: étape 2, image 3 de 3
    • Right side, remove 1 M1.4x3.7 screw
    • Left side, remove 3 M1.4x3.7 screws
    • Bottom side, remove 5 M1.4x3.7 screws, including 2 in battery bay. 2 of them out of this photo, you can find them.
    • Do NOT touch screws on the bottom of LCD assembly.
  3. Sony Alpha NEX-3N LCD assembly Replacement, Back Case 2: étape 3, image 1 de 1
    • Pop the flash.
    • In flash room, remove 1 (one) M1.4x3.8 black screw.
  4. Sony Alpha NEX-3N LCD assembly Replacement, Back Case 3: étape 4, image 1 de 3 Sony Alpha NEX-3N LCD assembly Replacement, Back Case 3: étape 4, image 2 de 3 Sony Alpha NEX-3N LCD assembly Replacement, Back Case 3: étape 4, image 3 de 3
    • Remove LCD hinge cover, by sliding to the left.
    • Remove back cover, actually just a plastic frame.
  5. Sony Alpha NEX-3N LCD assembly Replacement, LCD assembly: étape 5, image 1 de 2 Sony Alpha NEX-3N LCD assembly Replacement, LCD assembly: étape 5, image 2 de 2
    • Remove 1 M1.4x2 screw
    • Remove another M1.4x2 screw, sorry for the angle.
  6. Sony Alpha NEX-3N LCD assembly Replacement, LCD Assembly: étape 6, image 1 de 3 Sony Alpha NEX-3N LCD assembly Replacement, LCD Assembly: étape 6, image 2 de 3 Sony Alpha NEX-3N LCD assembly Replacement, LCD Assembly: étape 6, image 3 de 3
    • CAUTION. Sony makes world's MOST BRITTLE FPC!
    • Loosen LCD assemble with caution!
    • Release FPC cable, the connector is flip type.
  7. Sony Alpha NEX-3N LCD assembly Replacement, The LCD assembly: étape 7, image 1 de 1
    • The LCD assembly
Terrance
Membre depuis le 11/17/09
6 377 Réputation
17 tutoriels rédigés
Un commentaire
Where can i get a lcd screen replacement?
Searched everywhere even AliExpress they do not sell the replacement lcd for this model
adfa dad - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 51
Total : 1,132
