Aller au contenu principal
Sony Alpha SLT-A55V LCD Display Replacement
Ce dont vous avez besoin
  1. Sony Alpha SLT-A55V LCD Display Replacement, LCD Display: étape 1, image 1 de 2 Sony Alpha SLT-A55V LCD Display Replacement, LCD Display: étape 1, image 2 de 2
    • The LCD screen is located on the back of the SLT-A55V.
    • The screen folds out and can be rotated to view in several orientations.
  2. Sony Alpha SLT-A55V LCD Display Replacement: étape 2, image 1 de 1
    • Start the replacement by removing the rear cover of the camera.
    • The rear cover is attached with several screws on four sides of the camera. On the left side there are two screws near the clip for the wrist strap.
  3. Sony Alpha SLT-A55V LCD Display Replacement: étape 3, image 1 de 1
    • On the same side as the previous step lift the rubber flap that covers USB and the HDMI ports.
    • Remove two screws.
  4. Sony Alpha SLT-A55V LCD Display Replacement: étape 4, image 1 de 1
    • Remove three screws from the right hand side of the case.
  5. Sony Alpha SLT-A55V LCD Display Replacement: étape 5, image 1 de 1
    • Remove the screw that attaches the focusing adjustment for the eyepiece. The focusing wheel will also be removed.
  6. Sony Alpha SLT-A55V LCD Display Replacement: étape 6, image 1 de 1
    • On the bottom of the camera remove seven screws indicated by the circles in the picture to the left.
  7. Sony Alpha SLT-A55V LCD Display Replacement: étape 7, image 1 de 1
    • On the top of the camera there is a black plastic sticker that hides two screws which must be removed.
    • This sticker can be re-used. Peel the sticker off and place it on a clean piece of parchment paper or wax paper. This will prevent dirt and dust from getting on the adhesive.
    • Remove the two screws that lie beneath the sticker. The arrows indicate the location of these screws.
  8. Sony Alpha SLT-A55V LCD Display Replacement: étape 8, image 1 de 1
    • Using a nylon spudger, gently pry the cover open.
    • To do this step properly without damaging the back cover it is necessary to pry open the cover incrementally around the perimeter of the case.
  9. Sony Alpha SLT-A55V LCD Display Replacement: étape 9, image 1 de 1
    • After the cover has been opened, there are two ribbon cables connected to the back cover. These cables will be removed in the next step.
  10. Sony Alpha SLT-A55V LCD Display Replacement: étape 10, image 1 de 1
    Outil utilisé dans cette étape :
    • Using tweezers, gently remove the ribbon cables.
  11. Sony Alpha SLT-A55V LCD Display Replacement: étape 11, image 1 de 1
    • Unplug the ribbon cable indicated by the arrow on the left of the picture.
    • The arrow pointing to the black area indicates another sticker. This sticker will need to be removed in order to thread the ribbon cable through the back cover. This cable is attached to the LCD panel.
  12. Sony Alpha SLT-A55V LCD Display Replacement: étape 12, image 1 de 2 Sony Alpha SLT-A55V LCD Display Replacement: étape 12, image 2 de 2
    • Using a nylon spudger, separate the LCD case the same way the main housing was separated.
  13. Sony Alpha SLT-A55V LCD Display Replacement: étape 13, image 1 de 1
    • Unplug the ribbon cable from the LCD screen.
    • Replace the LCD screen and re-assemble in reverse order of these steps.
2 autres ont terminé cette réparation.
Sultan Almunif
Membre depuis le 09/26/15
357 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team 1-1, Wilson Fall 2015 Membre de l'équipe IUPUI, Team 1-1, Wilson Fall 2015
IUPUI-WILSON-F15S1G1
4 membres
6 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 9
30 derniers jours : 39
Total : 3,265
