Aller au contenu principal
Sony Alpha a7S II Motherboard Replacement
Ce dont vous avez besoin
  1. Sony Alpha a7S II Motherboard Replacement, Motherboard: étape 1, image 1 de 1
    • Remove the six 4mm screws located at the bottom of the camera using Philips #000 (Circled in red).
    • Remove the two 3mm screws remaining on the base plate using Philips #000 (Circled in orange).
    • Remove the base plate.
  2. Sony Alpha a7S II Motherboard Replacement: étape 2, image 1 de 3 Sony Alpha a7S II Motherboard Replacement: étape 2, image 2 de 3 Sony Alpha a7S II Motherboard Replacement: étape 2, image 3 de 3
    • Use the Philips #000 to remove the two 4mm screws located inside the battery holder.
    • Next, remove the two 4mm screws using the Philips #000 located on left side of the camera.
    • Remove one 4mm screw on the right side of the camera using Philips #000.
  3. Sony Alpha a7S II Motherboard Replacement: étape 3, image 1 de 1
    • Remove the two 3mm screws from the underneath the LCD screen.
    • Remove the screen.
  4. Sony Alpha a7S II Motherboard Replacement: étape 4, image 1 de 2 Sony Alpha a7S II Motherboard Replacement: étape 4, image 2 de 2
    • Remove the rubber viewfinder cap by sliding it upwards.
    • Remove the four 3mm screws behind the cap.
  5. Sony Alpha a7S II Motherboard Replacement: étape 5, image 1 de 2 Sony Alpha a7S II Motherboard Replacement: étape 5, image 2 de 2
    • Remove the outer case.
    • Unhook the component outlined by the red square.
    • Next, unscrew the two 4mm screws circled in orange using the Philips #000.
    • Remove the button outlined with the yellow square.
  6. Sony Alpha a7S II Motherboard Replacement: étape 6, image 1 de 2 Sony Alpha a7S II Motherboard Replacement: étape 6, image 2 de 2
    • Use a Phillips #000 screwdriver to remove the 4 mm screw from the housing.
    • The access door on the side of the camera must be open to reach the screw and remove the copper plate.
  7. Sony Alpha a7S II Motherboard Replacement: étape 7, image 1 de 3 Sony Alpha a7S II Motherboard Replacement: étape 7, image 2 de 3 Sony Alpha a7S II Motherboard Replacement: étape 7, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Gently pull the clip up on the wire ribbon ports.
    • Using the tweezers, gently pull the wire ribbons out of the ports.
    • Once the ribbon cables are disconnected, the motherboard can be removed.
Alicia Alanis-Angeles
Membre depuis le 04/12/22
148 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team 1-5, Beck Spring 2022 Membre de l'équipe IUPUI, Team 1-5, Beck Spring 2022
IUPUI-BECK-S22S1G5
4 membres
1 tutoriel rédigé
2 commentaires
Where can I order the motherboard for this camera?
Joshua Davis - Réponse
You can find replacement parts on Aliexpress.
Lou Bariller -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 35
30 derniers jours : 133
Total : 2,563
