Introduction
L'écran LCD peut être tiré sous deux angles différents. Cependant, soyez prudent lorsque vous le pêchez car il comporte des restrictions. Le faire au-delà de ces restrictions cassera le support LCD qui le maintient en place.
Ce dont vous avez besoin
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
8 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
[deleted] nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
4 commentaires
And the how do you change the LCD screen please ? How to remove it ?
I have the exact same question, I need to change the screen with flex cable as well. Thanks, there isn’t a lot of info on the a7s 2, it’s all a7r out there
Hello. My LCD backlight stop working after water came into the camera (snow). With a flash light I was able to determine it is the backlight since I was able to detect some menu items on the screen. I bought a replacement LDC unit, my thinking was that the backlight itself was damaged and a new one would do the trick. After replacing the screen, I have the same probleme. So I suppose my problem come from deeper in the camera. The camera itself do not command the backlight to turn on. Is there something I can do? any more troubleshooting?
Thanks!
What size screws!?
