Aller au contenu principal
Sony BDP BX350 Disc Assembly Replacement
Ce dont vous avez besoin
  1. Sony BDP BX350 Disc Assembly Replacement, Disc Assembly: étape 1, image 1 de 1
    • Remove the three 10mm Philips head screws on the back of the player.
  2. Sony BDP BX350 Disc Assembly Replacement: étape 2, image 1 de 1
    • Using an opening tool lift up the tabs located on the bottom of the plastic front cover.
  3. Sony BDP BX350 Disc Assembly Replacement: étape 3, image 1 de 1
    • Lift the tabs located on each side of the device to free the front cover. Begin to separate the front and metal back covers.
  4. Sony BDP BX350 Disc Assembly Replacement: étape 4, image 1 de 1
    • Completely separate the front cover and the metal back cover from the grey casing.
    • The inner components should all be completely exposed after opening.
  5. Sony BDP BX350 Disc Assembly Replacement: étape 5, image 1 de 1
    • Unscrew the two 8mm Philips head screws securing the disc assembly to the main casing.
  6. Sony BDP BX350 Disc Assembly Replacement: étape 6, image 1 de 1
    • Pull the disc assembly out from under the metal tabs on the main casing.
  7. Sony BDP BX350 Disc Assembly Replacement: étape 7, image 1 de 1
    • Remove disc assembly.
Kristen Vezina
Membre depuis le 03/06/17
413 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S8-G5, Catania Spring 2017 Membre de l'équipe UMass Dartmouth, Team S8-G5, Catania Spring 2017
UMASSD-CATANIA-S17S8G5
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 393
