Aller au contenu principal
Sony BDP-BX510 Outer Cover Replacement
Ce dont vous avez besoin
  1. Sony BDP-BX510 Outer Cover Replacement, Outer Cover: étape 1, image 1 de 1
    • Plug in the device to turn it on, then press the eject ( ⏏ ) button to open the tray.
  2. Sony BDP-BX510 Outer Cover Replacement: étape 2, image 1 de 2 Sony BDP-BX510 Outer Cover Replacement: étape 2, image 2 de 2
    • To remove the tray cover, hold both sides of the tray cover and gently apply a downward pressure.
    • Apply slightly more pressure to the left side until it unhooks then unhook the right side.
    • Close the disk tray by pressing the eject button again, then power off the device and unplug it.
    • Do not use too much force to remove the tray cover as you may break it.
  3. Sony BDP-BX510 Outer Cover Replacement: étape 3, image 1 de 2 Sony BDP-BX510 Outer Cover Replacement: étape 3, image 2 de 2
    • Turn to the back of the device.
    • Remove the two 7mm Phillips #2 screws.
    • Slide the two plastic covers on both sides of the device towards the back of the device to remove them.
  4. Sony BDP-BX510 Outer Cover Replacement: étape 4, image 1 de 3 Sony BDP-BX510 Outer Cover Replacement: étape 4, image 2 de 3 Sony BDP-BX510 Outer Cover Replacement: étape 4, image 3 de 3
    • Turn the device so you can see the bottom.
    • Unclip the three black plastic clips on the bottom of the device.
    • Unclip one clip on each side of the device.
  5. Sony BDP-BX510 Outer Cover Replacement: étape 5, image 1 de 1
    • Slide the cover forward to remove.
Niki Ngosi
Membre depuis le 01/19/20
375 Réputation
3 tutoriels rédigés
Équipe
York University, Team S1-G10, Woodhouse Winter 2020 Membre de l'équipe York University, Team S1-G10, Woodhouse Winter 2020
YORK-WOODHOUSE-W20S1G10
2 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 198
