Ce dont vous avez besoin
Plug in the Blu-Ray player, then press the power button, making sure the Blu-Ray player is powered on.
Press the eject button on either the top of the Blu-Ray player or on the remote to open the disc tray.
Locate the three 8 mm screws on the back of the Blu-Ray player.
Using the Phillips #2 screwdriver, unscrew each of the screws and set them aside.
Insert the nylon or metal spudger under the clip on the side near the front of the device. Lift the clip so it is free from the device.
Locate the large ribbon cable connecting the port board to the motherboard.
Detach the cable from the motherboard by carefully pulling upward on the cable.
Pull the small 5 pin ribbon cable out of its connector on the motherboard.
