Aller au contenu principal
Sony BDP-BX620 Disk Drive Replacement
Ce dont vous avez besoin
  1. Sony BDP-BX620 Disk Drive Replacement, Outer Cover: étape 1, image 1 de 2 Sony BDP-BX620 Disk Drive Replacement, Outer Cover: étape 1, image 2 de 2
    • Power on the device, eject the disk tray, and power off the device.
    • Turn the device over.
    • Lightly apply downward pressure on the black covering on the disk tray until it comes off.
    • Caution, applying too much pressure can break the black covering.
  2. Sony BDP-BX620 Disk Drive Replacement: étape 2, image 1 de 2 Sony BDP-BX620 Disk Drive Replacement: étape 2, image 2 de 2
    • Turn the device around.
    • Using a Phillips screw driver, remove the screws on both ends of the device circled red in the image.
    • Slide the side covers on either side towards the back of the device.
    • There is a back cover on either side of the device.
  3. Sony BDP-BX620 Disk Drive Replacement: étape 3, image 1 de 3 Sony BDP-BX620 Disk Drive Replacement: étape 3, image 2 de 3 Sony BDP-BX620 Disk Drive Replacement: étape 3, image 3 de 3
    • This step might require someone to help unclasping the plastic clips.
    • Turn the device so that the bottom is facing up.
    • In the bottom, unclip the three plastic clips circled in red.
    • On either side, unclip the plastic clip circled in red
    • Slide the black covering forwards to remove.
    • All five clips have to be unclasped for the covering to be removed.
    • Careful not to break the plastic clips when putting it back on.
  4. Sony BDP-BX620 Disk Drive Replacement, Disk Drive: étape 4, image 1 de 1
    • Remove the no-fuss ribbon cable connectors by gently pulling on them.
    • Pulling harshly may break the flat cables.
  5. Sony BDP-BX620 Disk Drive Replacement: étape 5, image 1 de 1
    • Using the Phillips screw driver, remove the three screws.
  6. Sony BDP-BX620 Disk Drive Replacement: étape 6, image 1 de 2 Sony BDP-BX620 Disk Drive Replacement: étape 6, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Turn the device over and use tweezers to push the metal clasp until it comes off.
    • Lift the metal brace located over the disk drive and remove the disk drive and the metal brace.
Axel Cruz Jimenez
Membre depuis le 10/05/16
207 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 1-6, Lacy Fall 2016 Membre de l'équipe USF Tampa, Team 1-6, Lacy Fall 2016
USFT-LACY-F16S1G6
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 358
