Introduction
This guild will guide you through removing and setting the motherboard.
Ce dont vous avez besoin
Power on the device, eject the disk tray, and power off the device.
Turn the device over.
Lightly apply downward pressure on the black covering on the disk tray until it comes off.
Gently pull on up on the power cord to unlatch it from the metal body of the device.
Remove the white ribbon cables connecting the motherboard to the display. The thick white ribbon cable in the middle needs the release button to be pressed down to allow it to come loose.
Remove the white ribbon cables connecting the motherboard to the disk drive. Be careful to not use too much force to not tear the cables.
Un commentaire
OK, but here’s the next step. I’m trying to get to the CPU now under that aluminum fin cooling plate. However, I can’t for the life of me find how to unhook those 4 hooks holding it down on the CPU. Any suggestions? Preferably without having to buy equipment, but if I must, what should I get?
