Aller au contenu principal
Sony BDP-S1 Fan Replacement
Ce dont vous avez besoin
  1. Sony BDP-S1 Fan Replacement, Sony BDP-S1: Getting inside the device: étape 1, image 1 de 2 Sony BDP-S1 Fan Replacement, Sony BDP-S1: Getting inside the device: étape 1, image 2 de 2
    • Remove the 12mm screws with the Philips #2 screwdriver which keep the plastic panels in place.
    • Don't forget, there are two more 12mm screws on the other side as well.
  2. Sony BDP-S1 Fan Replacement: étape 2, image 1 de 3 Sony BDP-S1 Fan Replacement: étape 2, image 2 de 3 Sony BDP-S1 Fan Replacement: étape 2, image 3 de 3
    • First, remove the three 12mm black screws holding the top panel on (Phillips #2).
    • Then, remove the two 12mm black screws - one on each side of the back of the device - holding the top panel on.
    • Lastly, remove the three 12mm black screws on each side of device.
  3. Sony BDP-S1 Fan Replacement: étape 3, image 1 de 3 Sony BDP-S1 Fan Replacement: étape 3, image 2 de 3 Sony BDP-S1 Fan Replacement: étape 3, image 3 de 3
    • Carefully lift up the top panel, because there are two blue ribbon cables that must be disconnected before removing the panel, and we do NOT want them to break.
    • After gently disconnecting the two ribbon cables (you can just pull them out with your hand), take the top off and set it to the side.
  4. Sony BDP-S1 Fan Replacement: étape 4, image 1 de 3 Sony BDP-S1 Fan Replacement: étape 4, image 2 de 3 Sony BDP-S1 Fan Replacement: étape 4, image 3 de 3
    • After the top is off, you'll see that there are two metal bars that go across the top of the device.
    • Remove each bar by unscrewing the two 10mm silver screws on each end.
  5. Sony BDP-S1 Fan Replacement, Fan: étape 5, image 1 de 3 Sony BDP-S1 Fan Replacement, Fan: étape 5, image 2 de 3 Sony BDP-S1 Fan Replacement, Fan: étape 5, image 3 de 3
    • First we need to unscrew the fan from before we can remove it.
    • Remove both copper colored 10mm screws with a #2 phillips screwdriver.
    • As you remove the second screw, pull the fan inward to remove it from the remainder of the case. It should now only be connected to the case through a cable attached to the circuit board.
    • The disk drive is removed in the pictures, however this is not necessary to replace the fan and can be ignored.
  6. Sony BDP-S1 Fan Replacement: étape 6, image 1 de 3 Sony BDP-S1 Fan Replacement: étape 6, image 2 de 3 Sony BDP-S1 Fan Replacement: étape 6, image 3 de 3
    • We will now completely remove the fan from the player.
    • Carefully detach the cable from the fan to the circuit board by pulling on the cable connecting the fan to the circuit board.
    • You are now ready to install the new fan!
Nicolas Kennedy
Membre depuis le 01/26/14
111 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 9-30, Maness Winter 2014 Membre de l'équipe Cal Poly, Team 9-30, Maness Winter 2014
CPSU-MANESS-W14S9G30
3 membres
5 tutoriels rédigés
2 commentaires
We're can i get a replacement fan for my Blu- ray player model BDV-E4100. HEEEEELP PLEASE.
darren cottenham - Réponse
Where can I get a replacement fan for my blue-ray player.
Christopher Meriweather - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 23
Total : 2,570
