Aller au contenu principal
Sony BDP-S3200 Motherboard Replacement
Ce dont vous avez besoin
  1. Sony BDP-S3200 Motherboard Replacement, Sony BDP-S3200 Disassembly: étape 1, image 1 de 1
    • Remove all cables from the device.
  2. Sony BDP-S3200 Motherboard Replacement: étape 2, image 1 de 2 Sony BDP-S3200 Motherboard Replacement: étape 2, image 2 de 2
    • Use a #1 Phillips screwdriver to remove the three screws located in the back of the device.
  3. Sony BDP-S3200 Motherboard Replacement: étape 3, image 1 de 1
    • Pull the top cover off by sliding back from the device once the screws have been taken out.
  4. Sony BDP-S3200 Motherboard Replacement, Motherboard: étape 4, image 1 de 2 Sony BDP-S3200 Motherboard Replacement, Motherboard: étape 4, image 2 de 2
    • Carefully detach the white strips from the motherboard.
    • Be sure to lift the black latch for the largest strip next to the disc drive before removing it.
  5. Sony BDP-S3200 Motherboard Replacement: étape 5, image 1 de 3 Sony BDP-S3200 Motherboard Replacement: étape 5, image 2 de 3 Sony BDP-S3200 Motherboard Replacement: étape 5, image 3 de 3
    • Remove screw above HDMI OUT port.
    • Remove screw above DIGITAL OUT port.
    • Remove the three screws on the motherboard.
    • Use a #1 Phillips screwdriver to remove all screws.
  6. Sony BDP-S3200 Motherboard Replacement: étape 6, image 1 de 2 Sony BDP-S3200 Motherboard Replacement: étape 6, image 2 de 2
    • Remove motherboard from the device.
    • Be careful not to damage any components of the motherboard when removing it from the device.
3 autres ont terminé cette réparation.
Brandon Correa
Membre depuis le 10/03/17
158 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S5-G2, Walkup Fall 2017 Membre de l'équipe USF Tampa, Team S5-G2, Walkup Fall 2017
USFT-WALKUP-F17S5G2
5 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 10
Total : 405
