Aller au contenu principal
Sony BDP-S3700 Motherboard Replacement
Ce dont vous avez besoin
  1. Sony BDP-S3700 Motherboard Replacement, Front Panel: étape 1, image 1 de 2 Sony BDP-S3700 Motherboard Replacement, Front Panel: étape 1, image 2 de 2
    • Use the PH1 screwdriver to remove the two 9mm screws on the back of the Blu-ray player.
  2. Sony BDP-S3700 Motherboard Replacement: étape 2, image 1 de 2 Sony BDP-S3700 Motherboard Replacement: étape 2, image 2 de 2
    • Remove the back of the device by slowly sliding the rear outer housing backwards.
  3. Sony BDP-S3700 Motherboard Replacement: étape 3, image 1 de 2 Sony BDP-S3700 Motherboard Replacement: étape 3, image 2 de 2
    • Turn the Blu-ray over
    • Pry open the clips under and on the sides
  4. Sony BDP-S3700 Motherboard Replacement: étape 4, image 1 de 1
    • Once all the clips are open, slide the front outer housing out.
  5. Sony BDP-S3700 Motherboard Replacement, Disc Drive: étape 5, image 1 de 3 Sony BDP-S3700 Motherboard Replacement, Disc Drive: étape 5, image 2 de 3 Sony BDP-S3700 Motherboard Replacement, Disc Drive: étape 5, image 3 de 3
    • Flip the Blu-ray back up
    • Remove the three ribbon cables that connect the disc drive to the motherboard.
    • Handle the circuits only on its side.
  6. Sony BDP-S3700 Motherboard Replacement: étape 6, image 1 de 2 Sony BDP-S3700 Motherboard Replacement: étape 6, image 2 de 2
    • Use a PH1 screwdriver to unscrew both of the 7mm screws on the side of the disc reader.
  7. Sony BDP-S3700 Motherboard Replacement: étape 7, image 1 de 1
    • Gently slide the disc drive to the right and lift up to remove the disc drive from the body of the player.
  8. Sony BDP-S3700 Motherboard Replacement, Motherboard: étape 8, image 1 de 2 Sony BDP-S3700 Motherboard Replacement, Motherboard: étape 8, image 2 de 2
    • Gently pull upwards on the ribbon cables to disconnect the motherboard from the Wi-Fi module and port board.
  9. Sony BDP-S3700 Motherboard Replacement: étape 9, image 1 de 3 Sony BDP-S3700 Motherboard Replacement: étape 9, image 2 de 3 Sony BDP-S3700 Motherboard Replacement: étape 9, image 3 de 3
    • Remove the three 7mm screws along the motherboard using a PH1 screwdriver.
  10. Sony BDP-S3700 Motherboard Replacement: étape 10, image 1 de 3 Sony BDP-S3700 Motherboard Replacement: étape 10, image 2 de 3 Sony BDP-S3700 Motherboard Replacement: étape 10, image 3 de 3
    • Remove the 4mm screw above the HDMI port and the 9mm screw Digital Out port.
  11. Sony BDP-S3700 Motherboard Replacement: étape 11, image 1 de 1
    • Carefully lift and pull the motherboard forward to remove.
2 autres ont terminé cette réparation.
Luiz Barreto
Membre depuis le 02/15/17
627 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 12-1, Eyestone Spring 2017 Membre de l'équipe USF Tampa, Team 12-1, Eyestone Spring 2017
USFT-EYESTONE-S17S12G1
4 membres
5 tutoriels rédigés
2 commentaires
Thanks for the guide really good! Does anyone know where i can get a sony bdp-s3700 motherboard replacement?
James Durham - Réponse
Same problem here.
Julian Robbins -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 18
Total : 1,480
