Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Sony BDV-NF620, utilisez notre manuel de réparation.
  1. Sony BDV-NF620 Teardown, Top cover screws: étape 1, image 1 de 3 Sony BDV-NF620 Teardown, Top cover screws: étape 1, image 2 de 3 Sony BDV-NF620 Teardown, Top cover screws: étape 1, image 3 de 3
    • This is it. A Sony BD/CD/DVD player, A/V receiver, amplifier and tuner, all in a PS3 Super Slim-looking device! Will all of these functions make it difficult to repair? Let's see!
    • Unplug the device before opening it!
    • Remove the seven PH1 screws marked with the circle under the player (they're marked with two half arrows on the device).
    • On the back of the device, remove the five PH1 screws marked in yellow (they're the same as the ones in the bottom).
  2. Sony BDV-NF620 Teardown, Top cover clips: étape 2, image 1 de 3 Sony BDV-NF620 Teardown, Top cover clips: étape 2, image 2 de 3 Sony BDV-NF620 Teardown, Top cover clips: étape 2, image 3 de 3
    • Insert a spudger (or other thin, plastic tools like that) in the small gap between the base and the top. Rotate it like in the picture and slide it across the side. You'll encouter some resistance where the clips are, it's normal.
    • Be careful not to break them!
    • Do the same for the front...
    • ...and for the other side.
  3. Sony BDV-NF620 Teardown, Top cover removal: étape 3, image 1 de 3 Sony BDV-NF620 Teardown, Top cover removal: étape 3, image 2 de 3 Sony BDV-NF620 Teardown, Top cover removal: étape 3, image 3 de 3
    • Lift the top cover about 5 cm (2 in) and place it in front of the device, with the curved side on the table.
    • Gently, remove the black felt tape.
    • Remove the touch keys's cable.
  4. Sony BDV-NF620 Teardown, Standby button: étape 4, image 1 de 3 Sony BDV-NF620 Teardown, Standby button: étape 4, image 2 de 3 Sony BDV-NF620 Teardown, Standby button: étape 4, image 3 de 3
    • Remove the two PH1 screws.
    • Remove the cable.
    • NEVER pull the cable from the wires! Always remove it by grabbing the connector.
    • Remove the single PH1 screw and detach the board from the plastic.
  5. Sony BDV-NF620 Teardown, Optical drive: étape 5, image 1 de 3 Sony BDV-NF620 Teardown, Optical drive: étape 5, image 2 de 3 Sony BDV-NF620 Teardown, Optical drive: étape 5, image 3 de 3
    • Now, back to the main device!
    • Remove the four PH1 screws and lift the shield out.
    • Remove the four PH1 screws (identical to the other four).
    • Gently rotate the optical drive 90 degrees.
  6. Sony BDV-NF620 Teardown, Optical drive cables: étape 6, image 1 de 3 Sony BDV-NF620 Teardown, Optical drive cables: étape 6, image 2 de 3 Sony BDV-NF620 Teardown, Optical drive cables: étape 6, image 3 de 3
    • Remove the three cables.
    • Remove the black felt tape
    • Insert a flathead screwdriver in the gap between the lower part of the optical drive and the little panel, rotate it and remove the panel.
  7. Sony BDV-NF620 Teardown, Optical drive lower panel: étape 7, image 1 de 3 Sony BDV-NF620 Teardown, Optical drive lower panel: étape 7, image 2 de 3 Sony BDV-NF620 Teardown, Optical drive lower panel: étape 7, image 3 de 3
    • Gently remove the cables from their plastic support tabs.
    • Insert a flathead screwdriver itn the hole near the L-shaped part. slightly rotate it downwards and slide the entire bottom of the drive right until it stops.
    • Lift the cover while being careful not to break the cables.
  8. Sony BDV-NF620 Teardown, Disc inlet: étape 8, image 1 de 2 Sony BDV-NF620 Teardown, Disc inlet: étape 8, image 2 de 2
    • Remove the three PH2 screws.
    • Slide the inlet to remove it.
  9. Sony BDV-NF620 Teardown, Top cover: étape 9, image 1 de 2 Sony BDV-NF620 Teardown, Top cover: étape 9, image 2 de 2
    • If you have a stuck disc, this is the step you are looking for!
    • Remove the three PH1 screws.
    • (I forgot to take the photo...) Insert a spudger (or similar) in the gap between the two parts of the drive and slide it along the corners. Around the yellow squares there are two clips which will pop when you slide the spudger.
    • Rotate the top cover and remove any stuck disc. Be careful not to break any part on the top!
  10. Sony BDV-NF620 Teardown, Display: étape 10, image 1 de 2 Sony BDV-NF620 Teardown, Display: étape 10, image 2 de 2
    • In the main unit, remove the display cable...
    • ...the IR sensor PH2 screw...
    • ...and the two PH2 orange screws.
    • Lift the display out of the unit.
  11. Sony BDV-NF620 Teardown, First shield: étape 11, image 1 de 2 Sony BDV-NF620 Teardown, First shield: étape 11, image 2 de 2
    • Remove the five PH2 screws (marked in the shield with double half arrows).
    • At the back, remove the single PH2 screw.
    • Lift the shield out.
  12. Sony BDV-NF620 Teardown, Second shield: étape 12, image 1 de 2 Sony BDV-NF620 Teardown, Second shield: étape 12, image 2 de 2
    • At the back of the device, remove the two PH2 screws.
  13. Sony BDV-NF620 Teardown, Logic board: étape 13, image 1 de 2 Sony BDV-NF620 Teardown, Logic board: étape 13, image 2 de 2
    • Remove the LED cable (grey) and side USB (black, fat).
    • Remove the fan, antenna, audio and power cables.
  14. Sony BDV-NF620 Teardown, Logic board: étape 14, image 1 de 3 Sony BDV-NF620 Teardown, Logic board: étape 14, image 2 de 3 Sony BDV-NF620 Teardown, Logic board: étape 14, image 3 de 3
    • Remove the fan screws and fan...
    • ...the antenna connector screws and module...
    • ...the audio, optical and (not shown) video screws (all of these are black PH2)...
    • ...(silver PH2) HDMI screws....
    • ...and finally the six PH2 logic board screws.
    • Last but not least rotate the board and slide towards you to remove it.
  15. Sony BDV-NF620 Teardown, Front LED: étape 15, image 1 de 3 Sony BDV-NF620 Teardown, Front LED: étape 15, image 2 de 3 Sony BDV-NF620 Teardown, Front LED: étape 15, image 3 de 3
    • Remove the single PH2 screw holding the light guide.
    • Lift and remove the light guide.
    • Remove the LED board.
  16. Sony BDV-NF620 Teardown, PSU Shield: étape 16, image 1 de 3 Sony BDV-NF620 Teardown, PSU Shield: étape 16, image 2 de 3 Sony BDV-NF620 Teardown, PSU Shield: étape 16, image 3 de 3
    • Remove the three PH2 screws on the shield.
    • Remove the shield by lifting it.
  17. Sony BDV-NF620 Teardown, Power supply nit: étape 17, image 1 de 3 Sony BDV-NF620 Teardown, Power supply nit: étape 17, image 2 de 3 Sony BDV-NF620 Teardown, Power supply nit: étape 17, image 3 de 3
    • Be careful: the big capacitors may still hold a little charge! Don't touch their leads!!!!
    • Remove the mains connector by pressing the little lever on it...
    • ...then the other two connectors...
    • And the five orange PH2 screws.
    • Grab the power supply unit by the central heat sink and lift it to remove.
  18. Sony BDV-NF620 Teardown, Audio board shield: étape 18, image 1 de 3 Sony BDV-NF620 Teardown, Audio board shield: étape 18, image 2 de 3 Sony BDV-NF620 Teardown, Audio board shield: étape 18, image 3 de 3
    • Remove the four orange PH2 screws.
    • At the back, remove the two upper PH2 screws.
    • Rotate the lower edge of the shield and pull it towards you to remove it.
    • When you reassemble it, pay attention to the plastic over it, as it can move and not protect the base of the power supply.
  19. Sony BDV-NF620 Teardown, Audio board: étape 19, image 1 de 3 Sony BDV-NF620 Teardown, Audio board: étape 19, image 2 de 3 Sony BDV-NF620 Teardown, Audio board: étape 19, image 3 de 3
    • Remove the black felt tape.
    • At the back, remove the single black PH2 screw over the speakers connectors.
    • Remove the bottom-left screw with wire-holder.
  20. Sony BDV-NF620 Teardown, Audio board: étape 20, image 1 de 2 Sony BDV-NF620 Teardown, Audio board: étape 20, image 2 de 2
    • Remove the three orange screws at the corners of the board.
    • Lift the black and red wires and remove the three orange PH2 screws (they're the longest screws in the device)
  21. Sony BDV-NF620 Teardown, Audio board: étape 21, image 1 de 2 Sony BDV-NF620 Teardown, Audio board: étape 21, image 2 de 2
    • Lift the heat sink...
    • Then rotate and pull towards you the audio board.
  22. Sony BDV-NF620 Teardown, Metal frame: étape 22, image 1 de 2 Sony BDV-NF620 Teardown, Metal frame: étape 22, image 2 de 2
    • Remove the three remaining screws on the lower plastic of the device.
  23. Sony BDV-NF620 Teardown, Metal frame: étape 23, image 1 de 2 Sony BDV-NF620 Teardown, Metal frame: étape 23, image 2 de 2
    • Rotate and lift the frame to remove it.
    • Congratulations, you've torn down the entire device!
  24. Sony BDV-NF620 Teardown: étape 24, image 1 de 1
    • Thanks to iFixit for the 10/10 image.
    • I think that this device deserves a 10-/10, because everything is easily removable, there are only five types of screws (and three different sizes) and the cables aren't glued but there's the foam tape holding them.
    • I gave the minus to the score because the IR receiver hasn't a connector but it's soldered and because the touch "keys" are glued onto the upper cover.
Federico Barutto
Membre depuis le 06/12/11
306 Réputation
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 28
Total : 4,540
