Introduction
Whether it's by dust or wear, the Main Button's Circuit Board can malfunction over time. This guide focuses on how to install a new Main Button's Circuit Board to get your device running like new.
Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
  • Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
Ajouter un commentaire
Use a plastic opening tool to pry the cover open.
  • Use a plastic opening tool to pry the cover open.
  • After the the cover is partly open as shown, remove the cover with your hands.
  • Detach the board from the ZIF connector using pair of tweezers or by hand.
  • Flip the circuit board over and remove the connector that is on the backside, now you can safely remove the circuit board.
Robert Tam
Membre depuis le 30/01/2013
6 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 7-12, Maness Winter 2013 Membre de l'équipe Cal Poly, Team 7-12, Maness Winter 2013
CPSU-MANESS-W13S7G12
5 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 273
