Aller au contenu principal
Sony CDX-GT540UI CD Drive Replacement
Ce dont vous avez besoin
  1. Sony CDX-GT540UI CD Drive Replacement, Front Panel: étape 1, image 1 de 1
    • Locate face-plate eject button.
  2. Sony CDX-GT540UI CD Drive Replacement: étape 2, image 1 de 2 Sony CDX-GT540UI CD Drive Replacement: étape 2, image 2 de 2
    • Press the eject button.
    • Remove the face-plate.
  3. Sony CDX-GT540UI CD Drive Replacement: étape 3, image 1 de 3 Sony CDX-GT540UI CD Drive Replacement: étape 3, image 2 de 3 Sony CDX-GT540UI CD Drive Replacement: étape 3, image 3 de 3
    • Remove two 4.9mm Phillips #00screws on the front of the device.
    • Remove two 7.5mm Phillips #00screws on the front of the device.
    • When the screws are removed, the eject lever may fall into the device. Make sure the device is held horizontal and level.
    The screws in red do not seem to need to be removed unless you are trying to replace the eject lever. If you're not trying to replace the lever, it adds an unnecessary complication to putting it back together.
    Dale Pearson - Réponse
  4. Sony CDX-GT540UI CD Drive Replacement: étape 4, image 1 de 2 Sony CDX-GT540UI CD Drive Replacement: étape 4, image 2 de 2
    • Rotate device 90 degrees to either side.
    • Use the plastic opening tool to pry open the top and bottom tab respectively.
    • Repeat on opposite side.
  5. Sony CDX-GT540UI CD Drive Replacement: étape 5, image 1 de 1
    • Remove front panel.
  6. Sony CDX-GT540UI CD Drive Replacement, Back Panel: étape 6, image 1 de 1
    • Locate back panel.
  7. Sony CDX-GT540UI CD Drive Replacement: étape 7, image 1 de 3 Sony CDX-GT540UI CD Drive Replacement: étape 7, image 2 de 3 Sony CDX-GT540UI CD Drive Replacement: étape 7, image 3 de 3
    • Remove four 11.5mm Phillips #00 (silver) screws from back panel.
  8. Sony CDX-GT540UI CD Drive Replacement: étape 8, image 1 de 1
    • Remove four 9.5mm Phillips #00 (black) screws from back panel.
    • Remove two 7.5mm Phillips #00 (black) screws from back panel.
  9. Sony CDX-GT540UI CD Drive Replacement: étape 9, image 1 de 1
    • Remove back panel.
    • On the back panel there will be thermal (white) paste. Do not touch.
  10. Sony CDX-GT540UI CD Drive Replacement, CD Drive: étape 10, image 1 de 1
    • Remove one 9.5mm Phillips #00 screw.
    • Rotate device 180 degrees and repeat step.
  11. Sony CDX-GT540UI CD Drive Replacement: étape 11, image 1 de 2 Sony CDX-GT540UI CD Drive Replacement: étape 11, image 2 de 2
    • Using plastic opening tool, detach the tabs. There are two on either side.
    • You will need to apply a decent amount of force to detach.
  12. Sony CDX-GT540UI CD Drive Replacement: étape 12, image 1 de 2 Sony CDX-GT540UI CD Drive Replacement: étape 12, image 2 de 2
    • Remove top panel.
  13. Sony CDX-GT540UI CD Drive Replacement: étape 13, image 1 de 1
    • Pull up CD drive slightly.
  14. Sony CDX-GT540UI CD Drive Replacement: étape 14, image 1 de 1
    • Disconnect motherboard connection.
  15. Sony CDX-GT540UI CD Drive Replacement: étape 15, image 1 de 1
    • Remove CD drive.
2 autres ont terminé cette réparation.
Odelkys Marquez
Membre depuis le 09/22/14
1 091 Réputation
7 tutoriels rédigés
Équipe
USF Tampa, Team 10-2, Brown Fall 2014 Membre de l'équipe USF Tampa, Team 10-2, Brown Fall 2014
USFT-BROWN-F14S10G2
3 membres
7 tutoriels rédigés
Un commentaire
This guide is listed as "difficult" yet only requires the use of a screwdriver and some prying tools. It would seem more appropriate to list it as "moderate" at most. I believe the motherboard guide has the same issue.
Also, you say PH#00 in the description of steps, but in the "tools" listing at the beginning of the guide, you said that a PH#0 was needed. These are not the same.
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 13
Total : 714
