Aller au contenu principal
Sony CDX-GT540UI Fuse Replacement
  1. Sony CDX-GT540UI Fuse Replacement, Wiring Harness: étape 1, image 1 de 1
    • Locate the clip on the wiring harness.
  2. Sony CDX-GT540UI Fuse Replacement: étape 2, image 1 de 2 Sony CDX-GT540UI Fuse Replacement: étape 2, image 2 de 2
    • Press down on the clip like you would an Ethernet cable.
    • Rock harness side to side, pulling gently towards you until harness detaches.
  3. Sony CDX-GT540UI Fuse Replacement, Fuse: étape 3, image 1 de 1
    • Once you have removed the wiring harness.
    • Locate the fuse.
  4. Sony CDX-GT540UI Fuse Replacement: étape 4, image 1 de 1
    • Using your index finger and thumb on either side of the fuse.
  5. Sony CDX-GT540UI Fuse Replacement: étape 5, image 1 de 1
    • Rock back and forth gently pulling towards yourself until the fuse is removed.
Odelkys Marquez
Membre depuis le 09/22/14
1 115 Réputation
7 tutoriels rédigés
Équipe
USF Tampa, Team 10-2, Brown Fall 2014 Membre de l'équipe USF Tampa, Team 10-2, Brown Fall 2014
USFT-BROWN-F14S10G2
3 membres
7 tutoriels rédigés
Un commentaire
I would like to sincerely thank the person or persons that took the time ,energy and effort to put forth this information in an easily accessible way. BASICALLY YOU ARE COOL !!
germanspeedster - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 20
30 derniers jours : 84
Total : 9,466
