Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Sony CFD-8 LCD Board Replacement
Ce dont vous avez besoin
  1. Sony CFD-8 LCD Board Replacement, Battery: étape 1, image 1 de 3 Sony CFD-8 LCD Board Replacement, Battery: étape 1, image 2 de 3 Sony CFD-8 LCD Board Replacement, Battery: étape 1, image 3 de 3
    • Remove the battery cover on the back of the boombox by applying downward pressure to the two clamps.
    • Be sure to unplug the boombox from the wall before attempting to open it for repair.
  2. Sony CFD-8 LCD Board Replacement: étape 2, image 1 de 2 Sony CFD-8 LCD Board Replacement: étape 2, image 2 de 2
    • Push against the positive end of each battery. Once it is loose, lift the battery out. Repeat for all six batteries.
    • The top row of batteries have the positive side pointing right. The bottom row of batteries have the positive side pointing left.
  3. Sony CFD-8 LCD Board Replacement, Front Panel: étape 3, image 1 de 3 Sony CFD-8 LCD Board Replacement, Front Panel: étape 3, image 2 de 3 Sony CFD-8 LCD Board Replacement, Front Panel: étape 3, image 3 de 3
    • Hold the boombox handle at an angle to access the screws behind the CD player.
    • Use a Phillips #1 screwdriver to unscrew the top two 14 mm screws. You may need a flashlight to see the screws.
  4. Sony CFD-8 LCD Board Replacement: étape 4, image 1 de 2 Sony CFD-8 LCD Board Replacement: étape 4, image 2 de 2
    • Remove four 14 mm screws using a Phillips #1 screwdriver. Two of these screws are at the bottom of the boombox and the other two are on either side of the boombox as highlighted in the related images.
    • All four screws have black arrows (not visible in the photo) indicating their location on the boombox.
  5. Sony CFD-8 LCD Board Replacement: étape 5, image 1 de 3 Sony CFD-8 LCD Board Replacement: étape 5, image 2 de 3 Sony CFD-8 LCD Board Replacement: étape 5, image 3 de 3
    • Gently separate the front panel from the back panel.
    • Remove the two connections holding the front panel to boombox.
    • One connection is located on the upper left hand side of the main circuit board.
    • The other is a large white strip slightly to the right of the cassette player.
    • Do not touch the cylindrical parts on the circuit board. These are capacitors and may deliver a shock!
    • Remove the front panel.
  6. Sony CFD-8 LCD Board Replacement, LCD Board: étape 6, image 1 de 1
    • Remove three 5mm screws from the back of the circuit board with a Phillips #1 screwdriver.
  7. Sony CFD-8 LCD Board Replacement: étape 7, image 1 de 1
    • Remove the circuit board.
Andrew Kleve
Membre depuis le 10/12/14
271 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 10-38, Amido Fall 2014 Membre de l'équipe Cal Poly, Team 10-38, Amido Fall 2014
CPSU-AMIDO-F14S10G38
5 membres
7 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 8
30 derniers jours : 28
Total : 812
