Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Sony CFD-8 Speaker Replacement
Ce dont vous avez besoin
  1. Sony CFD-8 Speaker Replacement, Front Panel: étape 1, image 1 de 3 Sony CFD-8 Speaker Replacement, Front Panel: étape 1, image 2 de 3 Sony CFD-8 Speaker Replacement, Front Panel: étape 1, image 3 de 3
    • Hold the boombox handle at an angle to access the screws behind the CD player.
    • Use a Phillips #1 screwdriver to unscrew the top two 14 mm screws. You may need a flashlight to see the screws.
    Demander à FixBot
    Ajouter un commentaire
  2. Sony CFD-8 Speaker Replacement: étape 2, image 1 de 2 Sony CFD-8 Speaker Replacement: étape 2, image 2 de 2
    • Remove four 14 mm screws using a Phillips #1 screwdriver. Two of these screws are at the bottom of the boombox and the other two are on either side of the boombox as highlighted in the related images.
    • All four screws have black arrows (not visible in the photo) indicating their location on the boombox.
    Demander à FixBot
  3. Sony CFD-8 Speaker Replacement: étape 3, image 1 de 3 Sony CFD-8 Speaker Replacement: étape 3, image 2 de 3 Sony CFD-8 Speaker Replacement: étape 3, image 3 de 3
    • Gently separate the front panel from the back panel.
    • Remove the two connections holding the front panel to boombox.
    • One connection is located on the upper left hand side of the main circuit board.
    • The other is a large white strip slightly to the right of the cassette player.
    • Do not touch the cylindrical parts on the circuit board. These are capacitors and may deliver a shock!
    • Remove the front panel.
    Demander à FixBot
  4. Sony CFD-8 Speaker Replacement, Speaker: étape 4, image 1 de 2 Sony CFD-8 Speaker Replacement, Speaker: étape 4, image 2 de 2
    • Use a 14cm Phillips #1 screwdriver to remove the four respective screws attaching the left and right speakers to the front panel.
    Demander à FixBot
  5. Sony CFD-8 Speaker Replacement: étape 5, image 1 de 1
    • Remove the speakers from the front panel.
    Demander à FixBot
2 autres ont terminé cette réparation.
Liam Kirsh
Membre depuis le 10/14/14
197 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 10-38, Amido Fall 2014 Membre de l'équipe Cal Poly, Team 10-38, Amido Fall 2014
CPSU-AMIDO-F14S10G38
5 membres
7 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 33
Total : 3,853
