Introduction
This guide will demonstrate how to open the radio and remove the speakers.
Ce dont vous avez besoin
Press down on the two tabs at the top of the door.
Rotate the door away from the radio, towards you.
Lift the door out of the three smaller tabs on the bottom.
Push the batteries against the spring and pull out using your finger to remove them.
Remove the 6 screws (30 mm in length) with the Phillips #2 Screwdriver from the large holes marked by arrows on the radio.
Carefully slice the glue holding the speaker wire at the top right corner of the front face with a sharp tool or a knife to separate the wire from the case.
Remove the 2 screws (10 mm in length) located on the corners of the speaker with the Phillips #2 screwdriver.
Repeat the process for the second speaker if you need to replace both speakers.
