Aller au contenu principal
Introduction
If the screen is damaged, then you may need to replace it. This guide will walk you through the process of replacing your screen with a new one.
  1. Sony Clie PEG-NR70 Screen Replacement, Screen: étape 1, image 1 de 1
    • Remove the two 1.5mm screws (one on the right and one on the left side) on the screen portion of the device with a Phillips #00 screwdriver.
  2. Sony Clie PEG-NR70 Screen Replacement: étape 2, image 1 de 1
    • Remove the two 1.5mm screws on the bottom of the screen module with a Phillips #00 screwdriver.
  3. Sony Clie PEG-NR70 Screen Replacement: étape 3, image 1 de 1
    • Remove the plastic wrapping on the side of the top portion of the device. This is done by first sliding the wrapping up to disengage the plastic hooks, then peeling the plastic away starting from either end.
  4. Sony Clie PEG-NR70 Screen Replacement: étape 4, image 1 de 1
    • Remove four 2.0mm screws on the side of the screen portion of the device with a Phillips #00 screwdriver.
  5. Sony Clie PEG-NR70 Screen Replacement: étape 5, image 1 de 1
    • Remove top .75mm screw of the top portion of device with a Phillips #00 screwdriver.
  6. Sony Clie PEG-NR70 Screen Replacement: étape 6, image 1 de 1
    • Remove front panel from the screen. You should be able to do this by gently pulling the pieces apart with your hands
  7. Sony Clie PEG-NR70 Screen Replacement: étape 7, image 1 de 1
    • Pry the screen from the back panel using the plastic opening tools to remove the screen module.
  8. Sony Clie PEG-NR70 Screen Replacement: étape 8, image 1 de 1
    • Remove the tape from the wires on the back side of the screen module.
  9. Sony Clie PEG-NR70 Screen Replacement: étape 9, image 1 de 1
    • Disconnect the screen from the device by gently pulling the two display data cables away from the bottom of the screen module with your fingers.
    • Be careful not to damage the display data cables! They are thin.
Courtney
Membre depuis le 19/04/2013
37 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 14-11, Maness Spring 2013 Membre de l'équipe Cal Poly, Team 14-11, Maness Spring 2013
CPSU-MANESS-S13S14G11
5 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 17
Total : 798
