Aller au contenu principal
Sony Clie PEG-T615C Battery Replacement
Ce dont vous avez besoin
  1. Sony Clie PEG-T615C Battery Replacement, Battery: étape 1, image 1 de 1
    • Remove two screws from the thumb dial panel on the back of the device.
  2. Sony Clie PEG-T615C Battery Replacement: étape 2, image 1 de 1
    • Remove one screw from the upper right corner on the back of the device.
  3. Sony Clie PEG-T615C Battery Replacement: étape 3, image 1 de 1
    • Remove one screw from the thumb dial panel on the right side of the device.
  4. Sony Clie PEG-T615C Battery Replacement: étape 4, image 1 de 1
    • Remove one screw from lower right side of the device.
  5. Sony Clie PEG-T615C Battery Replacement: étape 5, image 1 de 1
    • Remove one screw from the lower left side of the device.
  6. Sony Clie PEG-T615C Battery Replacement: étape 6, image 1 de 1
    • Remove two screws from the bottom of the device.
  7. Sony Clie PEG-T615C Battery Replacement: étape 7, image 1 de 1
    • Remove the thumb dial panel by sliding it away from the device.
    • You can do this step earlier, after you remove all of the screws from the thumb drive panel.
  8. Sony Clie PEG-T615C Battery Replacement: étape 8, image 1 de 1
    • Remove the back panel, exposing the inside of the device.
  9. Sony Clie PEG-T615C Battery Replacement: étape 9, image 1 de 1
    • Remove one screw located on the board below the battery.
  10. Sony Clie PEG-T615C Battery Replacement: étape 10, image 1 de 1
    • Unplug the male battery plug on the battery wire from the female battery plug on the board.
  11. Sony Clie PEG-T615C Battery Replacement: étape 11, image 1 de 1
    • Remove the battery by sliding it out of the side of the device.
Rob
Membre depuis le 10/04/11
1 Réputation
2 tutoriels rédigés
Équipe
UW Stout, Team 5-6, Zhou Fall 2011 Membre de l'équipe UW Stout, Team 5-6, Zhou Fall 2011
UWSTOUT-ZHOU-F11S5G6
4 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 10
Total : 2,285
